Thread: Realtion between pressure and area ?
    pressure p = force F/ area.pressure decrease with increase in area and increase with decrease in area. now in the nozzle, as area of nozzle decrease pressure reduce and velocity increase. Why?
    http://image.gostshare.com/files/ukl1rplu9bdo8koiwmnz.gif
  3. Re: Realtion between pressure and area ?
    Velocity increases because you transfer same volume from a smaller area.(q=Velocity*Area).
    when you have higher velocities, the flow pattern of the fluid will change and causes pressure drop.
    There is an additional point to think about, is the energy conservation equation, that means, that if the velocity increase (due of area reduction) the pressure must be reduce in order to keep the same energy qantity (less lost due to friction) see bernoulli principles.
  1. Determination of average drainage area pressure
    By pet_spec in forum Reservoir
    Last Post: 04-18-2013, 10:08 PM
  2. Article: Realtion between pressure and area ?
    By ameer in forum Home Articles
    Last Post: 01-23-2012, 06:53 PM
  3. Area classification of the area around diesel storage tank overflow
    By Mohamed in forum Safety And Environment
    Last Post: 11-23-2010, 05:49 AM
  4. Internal pressure and external pressure in pressure vessel
    By ekosusilo in forum Mechanical Engineering
    Last Post: 08-08-2010, 08:57 AM
  5. UTM to Area
    By meyssam1983 in forum Geology & Exploration
    Last Post: 07-07-2010, 02:08 PM
