[h=Separator Applications]2[/h] [table]
[TR]
[TD="width: 60%"]KW International builds a full line of Two and Three Phase Separators to meet any application with sizes ranging from 12 inch to 60-inch diameter in stock for immediate delivery. Separators constructed as Vertical or Horizontal with operating pressure from 125 psig to 1440 psig. Separators for exceptional conditions can be manufactured to engineered specifications.
[/TD]
[/TR]
[/table]
[table]
[TR]
[TD="width: 708, colspan: 2"][h=Vertical Separator Application]2[/h]
- [h=Low to moderate Gas to Oil production]2[/h]
- Capable of handling large slugs of liquids
- Removal of excessive quantities of sand, mud, and sediment.
- Upstream of process equipment tolerating no entrained liquids.
- Downstream of liquid formation processing
Two phase Vs Three Phase
Two-phase separators remove the liquids from the gas. Three phase separators separate the gas from the liquid and separate the oil from the free water. Separators cannot break an emulsion. Three phase separators use specific gravity and retention time to separate the oil and free water. In a three phase vertical separator the liquid droplets fall on an isolation baffle and flow through a downcomer into the liquid accumulation area where the oil and water are released near the oil-water interface to provide efficient separation.
[/TD]
[/TR]
[TR]
[TD="width: 354"]
Two-Phase Vertical Separator
[/TD]
[TD="width: 354"]
Three-Phase Vertical Separator
[/TD]
[/TR]
[/table]
[table]
[TR]
[TD] KW International builds a full line of two and three phase separators to meet any application with sizes ranging from 12 inch to 60-inch diameter in stock for immediate delivery.. Separators constructed as vertical or horizontal with operating pressure from 125 psig to 1440 psig. Separators for exceptional conditions can be manufactured to engineered specifications.
[/TD]
[/TR]
[/table]
[table]
[TR]
[TD="width: 707"][h=Horizontal Separator Application]3[/h]
- High gas to oil production
- Constant flow with small liquid surges
- Smaller in size for same gas capacity
- Higher gas velocities allowed with same efficiency of separation
- Greater liquid to gas interface area
- Improved release of solution gas and reduction of foam
- Three phase separation for efficient liquid-liquid separation
- Areas with vertical height limitations
- Applications requiring bucket and weir construction for three phase operation.
[h=Two phase Vs Three Phase]3[/h] Two-phase separators remove the liquids from the gas. Three phase separators separate the gas from the liquid and separate the oil from the free water. Separators cannot break an emulsion. Three phase separators use specific gravity to separate the oil and free water. Liquid levels in three phase separators are set by the oil spill over height. This is either set by an oil spill over baffle or a bucket and weir.
[/TD]
[TD] [/TD]
[/TR]
[/table]
[table]
[TR]
[TD] Easier installation and service with option of skid mounting and stacking in a piggy back fashion to form staged separation assemblies.
[/TD]
[/TR]
[/table]
[table]
[TR]
[TD="width: 71%"]
[/TD]
[/TR]
[/table]
[h=Picture Gallery]2[/h] [table]
[TR]
[TD="colspan: 2, align: center"]
[/TD]
[/TR]
[TR]
[TD="colspan: 2, align: center"] [/TD]
[/TR]
[TR]
[/TD]
[/TR]
[TR]
[/TR]
[TR]
[/TD]
[/TR]
[TR]
[/TR]
[TR]
[TD="width: 51%, align: center"]
[/TD]
[TD="width: 49%, align: center"]
[/TD]
[/TR]
[/table]
