Thread: DST flow rate
  1. DST flow rate
    I have a question about DST;
    In case if the fluid did not reach the surface, how can I calculate the flow rate?
    I saw in one of the forums it is possible to obtain the instantaneous rate flow pressure gain in fluid recorder, but could anybody explain me how to do that?
    thnx,
    silverzone
  3. When fluid level did not reach the surface, you can calculate flow rate like in slug test. See attached file.
    Attached Files Attached Files
  5. Thnaks a lot kochichiro,
    may i ask you the source of information, from which book you attached the document?
    rgrds,
  6. Bourdet Dominic - WELL TEST ANALYSIS THE USE OF ADVANCED INTERPRETATION MODELS
  1. Gas flow rate inside Pipeline
    By eng.7ossien in forum Engineering Spreadsheets & Presentations
    Last Post: 03-11-2015, 01:27 AM
  2. TEG flow rate
    By radu.scafariu in forum Oil And Gas Process
    Last Post: 05-15-2013, 07:40 AM
  3. Estimation of flow rate
    By arm in forum Reservoir
    Last Post: 06-09-2012, 10:16 PM
  4. Replies: 1
    Last Post: 07-15-2010, 05:47 PM
