Results 1 to 5 of 5
Thread: Q:What is the maximum allowable wall thickness reduction ratio in the pipelines?
    Or in another way, how can I calculate the required minimum pipe thickness
    Here is info what you should care about when you assessing your pipelines:
    Much aprreciate it dear selmagis
    Jan 2009
    Cairo, Egypt, Egypt
    Blog Entries
    4
    A formula in accordance with ANSI B31.3 "Code for pressure
    piping , petroleum refinery piping"
    T = Pido/2(SE+PiY)
    Where
    t = Pressure design thickness (in)
    Pi = Internal design pressure PSI
    do=Outside diameter of pipe (in)
    S = Allowable stresses
    E = Longitudinal weld joint factor, for seamless pipe = 1 and for ERW =
    0.85
    Y= Coefficient having values for ferritic steels as follows
    0.4 up to and including 480C
    0.5 for 510c
    0.7 for 540c and above
    (If you know original wall thickness of pipes)Calculation of minimum wall thickness of pipes based on allowable wall thickness reduction not more than 25% of original wall thickness
    Thanks dear khaled for your explination ,(Jazaka Alah Kaeran )
  1. pipeline wall thickness D/t2 ratio greater than 60
    By usarathy in forum Pipeline And Fluid Flow
    Last Post: 10-04-2013, 04:31 AM
  2. Wall Thickness
    By Tito Saul in forum Pipeline And Fluid Flow
    Last Post: 07-30-2013, 04:06 AM
  3. Standard Nozzle Maximum Allowable loads (For Pressure vessels, Tanks etc)
    By ramjiprasanna in forum Mechanical Engineering
    Last Post: 07-02-2013, 04:35 AM
  4. Replies: 0
    Last Post: 09-09-2011, 10:28 PM
  5. Maximum allowable film temperature for crude oil
    By owenb79 in forum Petroleum Refining
    Last Post: 09-06-2011, 12:48 PM
