I have a problem about high silica in steam,
How to calculate or predict silica in steam if i have Pressure Boiler and Silica content in water boiler??
thanks,![]()
thanks,![]()
My experience is on field: water silica vs steam silica. The only way is reduce silica in water.
To reduce Silica use continuous blow-down
The silica comes inside water demineralization. The continuous blowdown on the drum is to put out the solids in the steam then reduce also the silica but you spend much water demi.
plz upload good book on demineralisaton plant desin
