Thread: expansion calculation
  1. expansion calculation
    dear all,
    i need to know when completion engineers did the completion proposal and specify the interval of perforation did he take in consideration the expantion of the tubing inside the hole due to tempreture change and gravity or not? and is this expanded length will affect on pay zone interval and mistargeted the pay zone specailly when the depth been higher??
    also pls can you give me sheet specifing the expantion coffient of pipes and tubes using in oilfield operation?
    TQ
    Aug 2010
    Jakarta, Perth & Kuala Lumpur
    The casing is perforated not the tubing so as long as the perforating guns are not run on tubing, the tubing length has nothing to do with perforating depth. If perforating guns are run on tubing a gamma ray correlation is used to perforate on depth. The calculations you talk about have to do with tubing space out in the packer and landing the tubing hanger in the tubing head in the wellhead (so it is always in tension), and yes ALL completion engineers consider temperature/pressure effects etc...when calculating space out and tubing hanger tension etc...
  5. Quote Originally Posted by Chee Koh Peh View Post
    thanks very much chee
  1. Calculation of loads at Expansion Loop
    By aathar in forum Engineering Spreadsheets & Presentations
    Last Post: 06-29-2015, 02:23 PM
  2. piping expansion joint calculation
    By hammouda16 in forum Mechanical Engineering
    Last Post: 05-28-2013, 06:00 PM
  3. Subsea Pipeline End Expansion Calculation
    By steven tran in forum Pipeline And Fluid Flow
    Last Post: 07-16-2012, 06:08 AM
  4. Article: expansion calculation
    By ÃÈæ ÇáÚÈÇÓ in forum Home Articles
    Last Post: 12-22-2011, 03:40 PM
  5. tubing expansion calculation
    By ÃÈæ ÇáÚÈÇÓ in forum Drilling And Workover
    Last Post: 12-07-2011, 04:03 PM
