Page 1 of 2 1 2 LastLast
Results 1 to 12 of 16
Thread: Step by step: How to Install ETAP 7.0 and 7.5.0
    (include activation code ETAP)
    Oct 2009
    Dehli, Delhi, India, India
    Blog Entries
    1
    Nice
    Thanks u have done a nice thing for 1st timer. Keep it up.
  5. Nice .....
    All in one document...
    Thank you
    very good thank you!
  7. Hi guys,
    where can i find this installation tutorial for the Etap 7.5.0?
    Regards.
    Dec 2009
    Riau, Indonesia
    Hi Castilho
    Please search on this forum for posting "ETAP 7.0" or "ETAP 7.5.0", there is there
  10. Re: Step by step: How to Install ETAP 7.0 and 7.5.0
    Thanks Rudi!
    thank you where is the files
  12. Re: Step by step: How to Install ETAP 7.0 and 7.5.0
    thank u
  13. Re: Step by step: How to Install ETAP 7.0 and 7.5.0
    THANK sss
  14. Re: Step by step: How to Install ETAP 7.0 and 7.5.0
    thanks but I can't see anything aside these, "Step by step: How to Install ETAP 7.0 and 7.5.0
    (include activation code ETAP)".
  16. Re: Step by step: How to Install ETAP 7.0 and 7.5.0
    Read this:
    How to Install Etap-7 on Windows-7 32-bit
    1. Downloaded ETAP-7
    2. Disable connection to internet
    3. Disable antivirus software on your computer
    4. Press F2, go to user account control and disable it.
    5. Run Etap-7 installation from DVD.
    6. select install + license manager, just follow the instruction. Note : For Win-7 (and maybe Vista, but I never use vista) will show up UAC, just click/select enable to install
    7. When finish installation, dont run the software.
    8. Open folder LMSETUP\SYSTEM32\DRIVERS on etap DVD
    9. copy all files in the LMSETUP\SYSTEM32\DRIVERS ----- to ------ C:\Windows\System32\Drivers\
    10. Extract ETAP -------- Peta-6 then run file " etap6.exe " this is the software to bypass license.
    this file is under DOS file, so you will see DOS application run. Note : Why extract to Etap-7 folder, because I've ever fail to run it when extract outside etap 7 folder.
    9. After finish install --------, then Reboot your computer/laptop.
    10. Enable again your antivirus
    11. Run ETAp 7 application.
    11. Will show up window for license , click OK, then software will ask for activation serial
    Enter Activation serial : 9dp8kD6Ncc#Y8r5FBL+QEn3DHqDBKR<7Nc4/
    12. Then enjoy using ETAP 7
    Download the etap installer in 4shared.com or isohunt.com.
  1. Replies: 11
