what is three phase relative permeabilty???
I'm assuming you know what relative permeability is correct?
'normal' rel perm cures are two phase - typically oil & water or gas & water, and are often measured through steady or unsteady state lab methods.
Three phase curves are for systems with mobile oil, water AND gas - that is, three mobile phases -and typically is not measured but inferred from one of a number of different methods, the simplest being Stones Method(s). You can see some background on Stones method at page 3-4 of[link Point to another website Only the registered members can access]
thankz sir
and sir can u tel lme about the tringle curve which is made by the 3phase relative permeabilty?
The triangle (or ternary) plot is simply a three axis method to plot the three phase results.
