Thread: Hysys Orifice Plate User Operation
  1. Hysys Orifice Plate User Operation
    Hello,
    I am required to quickly develop an orifice plate user operation in HYSYS and am hoping that someone could help me if they have performed this task before.
    Any help would be greatly appreciated.
  3. The functionality of orifice plate can be coded as valve.
    For steady state - orifice plate provides the constant pressure drop for a given flow - so there is no problem.
    In case you are doing dynamic simulation, you need to provide the Cv value for the valve in the dynamics tab, you can also calculate the cv of valve by pressing the tab size the valve.
    I hope above helps
  1. Orifice Plate Installed Backwards
    By jnunez56 in forum Instrumentation & Control
    Last Post: 02-26-2014, 07:45 AM
  2. How to calculate orifice plate dia
    By satish987 in forum Instrumentation & Control
    Last Post: 05-01-2011, 06:48 PM
  3. Orifice Plate
    By mirfan389 in forum Pipeline And Fluid Flow
    Last Post: 04-12-2010, 03:37 AM
  4. Orifice Plate Process Design
    By pipe2000 in forum Oil And Gas Process
    Last Post: 09-16-2009, 06:28 PM
