Results 1 to 9 of 9
Thread: OLGA Buried pipe
    Jan 2009
    somewhere on the earth
    OLGA Buried pipe
    Dear Engineers
    How can I model the buried pipe in OLGA? Could I define the outer wall as soil with 1.5 m thickness?
  3. OLGA Buried pipe
    Hi,
    Following both options will give the same results.
    You can calculate equivalent burial depth using the equation from OLGA users manual
    OR
    Use the actual burial depth (if it is 1.5 m) and descretize the soil layer. When you descretize the wall, it should be noted that the ratio of adjacent wall thickness should be <=5
    FluidFlow
    Jan 2009
    Thanks a lot FluidFlow
    Jan 2009
    Dear FluidFlow
    I've buried a pipe as the attached scheme (1 meter underground), then defined a soil wall with 1 meter thickness. my question is: what are the ambient T and K? note that the 3 sides of the pipes is surrounded by soil and the 4th side surrounded by air.
    thanx engineer
    Jan 2009
    See the attached file to find the answer, I think.
  9. interesting discussion
    Dear motaleby,
    May I get other manual of OLGA 7? Thanks before
    Jan 2009
    Install OLAG 7 then go to installed folder and find OLGA help in chm and pdf formats
  12. Re: OLGA Buried pipe
    Hi Fluid flow,
    I came across same problem recently but didnt find a solution, pls. if you can tell the equations from olga manual for this as i am unable to find them. Also, if you can elaborate further on the soil descretize option.
    thanks in advance.
    Abhineet
  1. Buried Flexible Pipe
    By kacu_88 in forum Pipeline And Fluid Flow
    Last Post: 12-19-2013, 01:06 PM
  2. buried pipe in stainless steel
    By giruffo in forum Materials Science &Corrosion
    Last Post: 06-15-2013, 03:27 PM
  3. Buried Pipe
    By Mr Welder in forum Mechanical Engineering
    Last Post: 03-24-2013, 10:15 AM
  4. Article: OLGA Buried pipe
    By motaleby in forum Home Articles
    Last Post: 12-19-2011, 04:22 AM
  5. protection for the buried pipe
    By cytech in forum Materials Science &Corrosion
    Last Post: 02-27-2011, 07:24 AM
