Thread: Looking for Technical Guidance Note (Dispersion) Technical Guidance Note
  1. Looking for Technical Guidance Note (Dispersion) Technical Guidance Note
    Im looking for the following:
    Technical Guidanc Note (Dispersion) D1 - Guidelines on Discharge Stack Heights for Polluting Emissions, 1993
    "Lays out a relatively simple, non-specific method of approximately determining the heights of discharge stacks for polluting emissions, which should be adequate in normal circumstances. It is intended for use by inspectors, local authorities, industry and others who have a need to make such calculations, although it is primarily intended for use with those processes regulated by local authorities."
    SOMEONE CAN HELP ?
    I would like also to see asked Guidance. Maybe this could be interesting for you:
    Thank you
  6. thank you
  1. Urgently need this technical paper or any related technical report
    By finiteinjustice in forum Materials Science &Corrosion
    Last Post: 07-20-2014, 01:48 PM
  2. newbie need guidance
    By leon_aurel in forum Electrical & Power Engineering
    Last Post: 01-23-2012, 03:54 PM
  3. Replies: 0
    Last Post: 01-17-2012, 03:57 PM
  4. Need Guidance and Help
    By gulsher in forum Jobs
    Last Post: 02-04-2011, 02:26 AM
  5. guidance notes
    By geoffd5058 in forum Safety And Environment
    Last Post: 04-27-2010, 10:16 PM
