Thread: What is difference between code and standard and specification
    The integrity of a piping system depends on the considerations and principles used in design, construction and maintenance of the system. Piping systems are made of components as pipes, flanges, supports, gaskets, bolts, valves, strainers, flexible and expansion joints. The components can be made in a variety of materials, in different types and sizes and may be manufactured to common national standards or according a manufacturers proprietary item. Some companies even publish their own internal piping standards based upon national and industry sector standards. Piping codes and standards from standardization organizations as ANSI ASME ISO DIN and others, are the most common used. The difference between piping codes and piping standards can be summarized: Piping Codes Piping codes defines the requirements of design, fabrication, use of materials, tests and inspection of pipes and piping systems. A code has a limited jurisdiction defined by the code. Piping Standards Piping standards define application design and construction rules and requirements for piping components as flanges, elbows, tees, valves etc. A standard has a limited scope defined by the standard.
    See the following definitions for code, standard & Specifications as derived at "The Piping Guide"
    for the design and drafting of industrial piping systems, and from ASME point of view:
    Link:
  5. Code is recommended method of doing something.
    • ASME BPV – TEMA
    Standard is the degree of excellence required.
    • API 660-ASME B16.5–ASME B36.10M–ASME B36.19-ASME B16.9–ASME B16.11
    Specification is a detailed description of construction, materials… etc
    • Contractor or Owner specifications
    to make it simple
    Code is mandatory
    Standard is recommendatory
    Cheers
    Thank you very much
    Victor Lachica
  1. Replies: 14
    Last Post: 01-06-2015, 11:00 AM
  2. Replies: 1
    Last Post: 09-16-2011, 11:15 PM
  3. Replies: 0
    Last Post: 09-09-2011, 10:47 PM
  4. What is difference between code and standard and specification
    By Esam in forum Pipeline And Fluid Flow
    Last Post: 09-05-2011, 12:43 PM
  5. what the difference between ATEX and CSA specification
    By gendy in forum Instrumentation & Control
    Last Post: 10-28-2010, 03:23 PM
