Results 1 to 8 of 8
Thread: Centrifugal Pumps 2nd Edition by Johann Friedrich Gülich
    "Centrifugal Pumps" by Johann Friedrich Gülich
    Publisher: Springer
    ISBN: 3642128238
    Edition 2010
    This book gives an unparalleled, up-to-date, in-depth treatment of all kinds of flow phenomena encountered in centrifugal pumps including the complex interactions of fluid flow with vibrations and wear of materials. The scope includes all aspects of hydraulic design, 3D-flow phenomena and partload operation, cavitation, numerical flow calculations, hydraulic forces, pressure pulsations, noise, pump vibrations (notably bearing housing vibration diagnostics and remedies), pipe vibrations, pump characteristics and pump operation, design of intake structures, the effects of highly viscous flows, pumping of gas-liquid mixtures, hydraulic transport of solids, fatigue damage to impellers or diffusers, material selection under the aspects of fatigue, corrosion, erosion-corrosion or hydro-abrasive wear, pump selection, and hydraulic quality criteria
    Links :
    Thank for shared.
    Good sharing.
    tsrc8204.
    Thanks for sharing
    thank you
    thank you
    Thanks!
  11. Re: Centrifugal Pumps 2nd Edition by Johann Friedrich Gülich
    can you re upload the file because I need it fo my master and if you have centrifugal pump design by gohn tozson
  1. Centrifugal Pumps and Standards
    Last Post: 01-26-2012, 01:34 PM
  2. Replies: 0
    Last Post: 07-26-2011, 11:36 AM
  3. Centrifugal Pumps by Johann Friedrich Gulich
    By Azad in forum Pipeline And Fluid Flow
    Last Post: 03-24-2010, 07:04 PM
  4. Centrifugal Pumps (Part- I)
    By Mohamed in forum Mechanical Engineering
    Last Post: 09-17-2009, 09:01 AM
