Thread: Centrifugal Pumps by Johann Friedrich Gulich
    Centrifugal Pumps
    Author(s): Johann Friedrich Gulich
    Publisher: Springer
    Date : 2007-11-14
    ISBN-10 : 3540736948
    This book gives an unparalleled, up-to-date, in-depth treatment of all kinds of flow phenomena encountered in centrifugal pumps including the complex interactions of fluid flow with vibrations and wear of materials.
    The scope includes: all aspects of hydraulic design, 3D-flow phenomena and partload operation, cavitation, numerical flow calculations, hydraulic forces, pressure pulsations, noise, pump vibrations (notably bearing housing vibration diagnostics and remedies), pipe vibrations, pump characteristics and pump operation, the effects of highly viscous flows, pumping of gas-liquid mixtures, hydraulic transport of solids, fatigue damage to impellers or diffusers, material selection under the aspects of fatigue, corrosion, erosion-corrosion or hydro-abrasive wear, pump selection, and hydraulic quality criteria.
    To ease the use of the information, the methods and procedures for the various calculations and failure diagnostics discussed in the text are gathered in more than 100 pages of tables which may be considered almost unique in the open literature. The text focuses on practical application in the industry and is free of mathematical or theoretical ballast. In order to find viable solutions in practice, the physical mechanisms involved should be thoroughly understood. The book is focused on fostering this understanding which will benefit the pump engineer in industry as well as academia and students.
    Links :
  3. thanks a lot
  1. Centrifugal Pumps 2nd Edition by Johann Friedrich Gülich
    By Azad in forum Mechanical Engineering
    Last Post: 04-29-2013, 06:35 PM
  2. Centrifugal Pumps and Viscosity
    Last Post: 01-26-2012, 01:35 PM
  3. Centrifugal Pumps and Standards
    Last Post: 01-26-2012, 01:34 PM
  4. Replies: 0
    Last Post: 07-26-2011, 11:36 AM
