[h=Degree Engler]4[/h] Degree Engler is used in Great Britain as a scale to measure kinematic viscosity. Unlike the Saybolt and Redwood scales, the Engler scale is based on comparing a flow of the substance being tested to the flow of another substance - water. Viscosity in Engler degrees is the ratio of the time of a flow of 200 cubic centimetres of the fluid whose viscosity is being measured - to the time of flow of 200 cubic centimeters of water at the same temperature (usually 20oC but sometimes 50oC or 100oC) in a standardized Engler viscosity meter.
[h=Newtonian Fluids]3[/h] Fluids for which the shearing stress is linearly related to the rate of shearing strain are designated as Newtonian Fluids.
Newtonian materials are referred to as true liquids since their viscosity or consistency is not affected by shear such as agitation or pumping at a constant temperature. Fortunately most common fluids, both liquids and gases, are Newtonian. Water and oils are examples of Newtonian liquids.
[h=Shear-thinning or Pseudoplastic Liquids]3[/h] Shear-thinning or pseudoplastic liquids are those whose apparent viscosity decreases with increasing shear rate. Their structure is time-independent.
[h=Thixotropic Fluids]3[/h] Thixotropic liquids have a time-dependent structure. The apparent viscosity of a thixotropic liquid decreases with increasing time, at a constant shear rate.
Ketchup and mayonnaise are examples of thixotropic materials. They appear thick or viscous but are possible to pump quite easily.
[h=Dilatant Fluids]3[/h] Shear Thickening Fluids or Dilatant Fluids increase their viscosity with agitation. Some of these liquids can become almost solid within a pump or pipe line. With agitation, cream becomes butter and Candy compounds, clay slurries and similar heavily filled liquids do the same thing.
[h=Bingham Plastic Fluids]3[/h] Bingham Plastic Fluids have a yield value which must be exceeded before it will start to flow like a fluid. From that point the viscosity will decrease with increase of agitation. Toothpaste, mayonnaise and tomato catsup are examples of such products.
[h=Example - Converting between Kinematic and Absolute Viscosity for Air]3[/h] Kinematic viscosity of air at 1 bar (105 Pa, N/m2) and 40oC is 16.97 cSt (16.97 10-6 m2/s).
The density of air estimated with the Ideal Gas Law
ρ = p / R T
where
ρ = density (kg/m3)
p = absolute pressure (Pa, N/m2)
R = individual gas constant (J/kg K)
T = absolute temperature (K)
ρ = (105 N/m2) / ((287 J/kg/K) (273 oC + 33 0C)
= 1.113 kg/m3
Absolute viscosity can be expressed as
μ = (1.113 kg/m3) (16.97 10-6 m2/s)
= 1.88 10-5 (kg/m s, Ns/m2, P)
[h=Viscosity and Specific Gravity of some Common Liquids]3[/h] centiStokes
(cSt) |
Saybolt Second
Universal
(SSU, SUS) |
Typical liquid |
| 1 |
31 |
Water (20oC) |
| 4.3 |
40 |
Milk
SAE 20 Crankcase Oil
SAE 75 Gear Oil |
| 15.7 |
80 |
No. 4 fuel oil |
| 20.6 |
100 |
Cream |
| 43.2 |
200 |
Vegetable oil |
| 110 |
500 |
SAE 30 Crankcase Oil
SAE 85 Gear Oil |
| 220 |
1000 |
Tomato Juice
SAE 50 Crankcase Oil
SAE 90 Gear Oil |
| 440 |
2000 |
SAE 140 Gear Oil |
| 1100 |
5000 |
Glycerine (20oC)
SAE 250 Gear Oil |
| 2200 |
10,000 |
Honey |
| 6250 |
28,000 |
Mayonnaise |
| 19,000 |
86,000 |
Sour cream |
Kinematic viscosity can be converted from SSU to Centistokes like
νCentistokes = 0.226 νSSU - 195 / νSSU
where
νSSU < 100
νCentistokes = 0.220 νSSU - 135 / νSSU
where
νSSU > 100
[h=Viscosity and Temperature]3[/h] Kinematic viscosity of liquids like water, mercury, oils SAE 10 and oil no. 3 - and gases like air, hydrogen and helium are indicated below. Note that
- for liquids viscosity decreases with temperature
- for gases viscosity increases with temperature
