Results 1 to 11 of 11
Thread: [ Help ] How to Determine Pressure Drop in PipeSim
    Assalamualaikum.Wr.Wb
    Hai every body,.
    for i first time, may i introduce my self, i'm dzaky . i'm a collage student in one of university in Indonesia. Now, i still doing my final assignment about "analysis Pressure drop in one filed with multiphase correlation".
    for first time, i'm sorry if i ask about my problem on in-correct thread here...
    actually i plan to determine the pressure drop of several well in one oil field, the pressure drop which i want to determine about 2 point , it's from well head to storage station, actually the field is multiphase flow,
    I plan to determine it with PipeSim with horizontal multiphase correlation such as Dukler I/II correlation, beggs and Brill Correlation, or Hagedorn and Brown Correlation. I plan to determine it in PipeSim.
    Can i determine it in pipeSim?? actually i still confuse to operate the software, have any one ever determine the pressure drop between 2 point with PipeSim?? ( i hope someone can share his/her experience in this problem...)
    i still confuse , what should i do in operate the software, what should i do first? should i build the model with well/pipeline model option or i should make it with network model...?? and what option should i take in operations toolbar : the pressure/temperature profile? or other option??
    hope some one here can help me about my problem....
    and thanks a lot for time and attention every one here who willing help me here... hope Allah will bless your kindness .
    Wassalam
    Ahmad Dzaky
    still waiting for any advice from all of the member here....
    please some body help me...
    need your advice here.....
    Wassalam
    A. Dzaky
    Jan 2009
    somewhere on the earth
    Dear dzaky_petro
    You must run the network.
    1- Define a well (add source from the left bar)
    2- Double click on it and set temperature and flow rate (gas or liq, if they are gas wells or oil wells respectively)
    3- Define all wells as above
    4- Add a junction from the left bar menu
    5- Connect all wells to the junction with branch tool (from the left bar menu)
    6- Now you see some pipeline between wells and junction named B1, B2,..
    7- Double click on each B and define your pipeline (ID, Thickness, Profile, Temperature, Heat transfer U, above or underground,…)
    8- Now you should have a receiver maybe refinery, end user,... (add a sink from the left bar menu)
    9- Connect the junction and sink by a branch
    10- If you need pressure drops in the manifold (junction), double click on pipeline between junction and sink, remove pipeline and then connect them with connector tool (on the top bar menu)
    11- If you want to transmit the fluid as a single phase, add a separator between junction and sink. Gas type separator removes gas from the line and send oil to the pipeline or sink.
    12- Double click on the sink and set the pressure or rate. It’s better to set the pressure (the trail will have the better answer)
    13- Run the model
    14- You can see the pressures by report tools or move mouse over any points (Source, Pipeline, Junction and Sink)
    Good luck friend
    Quote Originally Posted by motaleby View Post
    dzaky_petro
    1- Define wells (add source from the left bar)
    8- Now you should have a receiver (add sink from the left bar menu)
    9- Connect junction and sink by a branch
    10- If you need pressure drops in the manifold (junction), double click on pipeline between junction and sink, remove pipeline and then connect them with connector tool (on the top bar)
    11- If you want transmit the fluid as a single phase, add a separator between junction and sink. Gas type separator remove gas from the line and send oil to the pipeline or sink.
    13- Run the model
    Good luck friend
    Thanks a lot Mr.motaleby to your suggestion in my problem..
    i will try to build it first Mr.
    Thanks a lot...
    A.Dzaky
    dzaky_petro
    13- Run the model
    Good luck friend
    Mr.Motaleby..
    may i ask you something....
    i have tried the illustration that you given to me,..
    for exercise i tried model contain 2 source....and i follow all of the your instruction , but while i run it the are something error here...
    the error reported that...
    "Invalid Model
    Error in Boundary condition : number of pressure, Flowrate or PQ Curve spec doesn't match number of source/sink"...
    actually.
    i run 2 source with different Pressure and flowrate...
    source_1 : P = 75 psi, Q=378 stb/d
    source_2 : P= 105 psi, Q=868 stb/d..
    here is my model....
    Uploaded with
    there is something wrong here sir...???
    Jan 2009
    dear friend
    upload again
    here is my model sir...
    http://images****.us/photo/my-images/708/pipesim.jpg/
    thanks again for your goodness sir.
    Jan 2009
    Dear Dzaky
    as i guessed you've entered too many known parameters for your sources and sink. you must set one of the "P and Q" for a source or sink. I suggest set Q for the wells and P for the sink. Double click on the wells and delete P value and then remove Q value from the Sink. If you do these right, you'll see below the wells Q (current: PQ) and below the Sink P (current: PQ).
    Keep on Engineer!
    Dear Dzaky
    Keep on Engineer!
    oh...
    my mistake , i think i can input both P and Q in one source, but it can't...
    so, it's alternate while we enter P in Source 1 in other way, we have to enter Q in sink...
    Ok. i'm understand Sir....
    Thanks a lot Mr.Motaleby, i hope Allah SWT will bless you for your goodness to me Mr.Moteleby....
    Thanks again Sir..
    A.Dzaky
    Jan 2009
    let me know if you have another problem
    good luck friend
  14. #11
    Re: [ Help ] How to Determine Pressure Drop in PipeSim
    Hi Forum,
    Pipesim 2018 full working now with me. Ready to share.
    Some other applications like Eclipse 2018, Kappa 5.2, CMG 2018 and ... are also available.
    I will be happy if you interested in exchange. follow me on this address:
    tnudefski@gmail.com
  1. How to determine pipe sch based on pressure
    By soebadri in forum Pipeline And Fluid Flow
    Last Post: 01-28-2014, 05:47 PM
  2. pressure drop in a pipe
    By halcyon304 in forum Pipeline And Fluid Flow
    Last Post: 10-03-2013, 01:00 PM
  3. Article: [ Help ] How to Determine Pressure Drop in PipeSim
    By dzaky_petrol@yahoo.com in forum Home Articles
    Last Post: 07-26-2011, 12:23 AM
