Dear Friends,
thePetroStreet team is about to release their next engineering software "ClampOX®" focusing on box-up /clamp design for piping leakages.
ClampOX® is capable of designing both hot box-up (welded) and cold box-up (bolted) based upon user's input.
See the first look at below attachment:
The salient features of ClampOX® are as follows:
1. Basic clamp thickness calculations based on ASME VIII pressure design formula
2. Calculation of weld leg dimension for hot box-up (welded)
3. Basic clamp thickness calculations for cold clamp on ASME VIII and structural analysis against line pressure / injection pressure
4. Commonly available and used materials for clamps / pipe / lug have been listed along with their stress values against input temperature
5. Provides liberty to the user for input of all required data if not in scope of ClampOX material library
6. Provides all the required output which a design engineer would require
7. Detailed sketch of cold box-up with all required dimensions including:
a. Clamp thickness
b. Lug thickness
c. Lug length
d. Lug width
e. Weld led dimension for lug attachment
8. For bolted clamps, ClampOX generates the required bolt diameter and bolt spacing also however number of bolts have to be specified by user
9. General notes have been provided within the software for basic information of user
10. Free to download & use
Software is expected to be released by the first week of July 2011.
You are welcome to please provide us your comments and get to know about any updates at the following link:
Ashfaq
