Hi everyone, is it posible or recomendable to weld A-333 Gr.7 pipe with fittings A-420 WPL3/A-350 LF3, the intention is to use A-333 Gr7 instead of A-333 Gr.3 (only pipe). As in the project there are way more pipe than fittings and for the operating temperature A-333 Gr.7 is enough, but the problem is that there are no equivalent fittings for A-333-Gr.7, so I want to use A-333- Gr3 compatible fittings with A-333.Gr7 pipe.
One material es P-number 9A and the other is 9B, it might be some problems to weld these materials?, or preparing a good WPS will be enough?
Thanks for you suggestions
