Page 1 of 4 1 2 3 ... LastLast
Results 1 to 12 of 37
Thread: Pipe Welding Procedures
  1. Pipe Welding Procedures
    A standard reference for decades, this new edition of Pipe Welding Procedures continues to reinforce the welder's understanding of procedures. Drawing on his extensive practical and teaching experience in the field, the author describes in detail the manipulating procedures used to weld pipe joints. You will find useful information on heat input and distribution, essentials of shielded metal-arc technology, distortion, pipe welding defects, welding safety, essentials of welding metallurgy, and qualification of the welding procedure and the welder.
    Table of Contents:
    Essentials of Shielded Metal-Arc Welding Technology
    Heat Input and Distribution
    Preparation of the Pipe Joint
    Uphill Welding the Root Bead on Heavy-Wall Pipe
    Welding the Root Bead by the Gas Tungsten Arc Welding Process
    The Intermediate and Cover Passes
    Welding Thin Wall Pipe
    Horizontal Pipe Welding (2G)
    Welding Complicated Pipe Joints
    Introduction to Welding Metallurgy
    Distortion in Pipe Welding
    Pipe Welding Defects
    Fitting-up Pipe
    Qualification of the Welding Procedure and the Welder
    General Welding Safety
    Look for new or expanded coverage of:
    Root Bead--Pulse Current--Gas Tungsten Arc Welding
    Shielded Metal Arc WeldingElectrode
    Welding Steel for Low Temperature (Cryogenic) Service
    Down Hill WeldingHeavywall and Large Diameter
    Welding Metallurgy
    Weld Repair
    Thanks for the"welding" stuff...essential part of the Fabrication process.
  5. thank so much.
  6. Tks
    Thanks 4 sharing ............
    thank u brother
  9. Hi to all. i join this wonderful forum today. i find it very useful. i will also try to contribute my share in this.
    Abdel fatah
    thank u brother
  11. thanks for sharing ..best for you
  12. thanks a lot sir
  13. Hi Guys
    can you please share ******** for Welding Pro-Write, TWI Weldspec 4, TWI NDTspec 4 for Welding NDT, WPS, PQR.
    Thank you soo much
  14. thanq
  16. link is not valid...please reupload it again.. thanks
  1. Pipe Weld Procedures
    By BornToSin in forum Pipeline And Fluid Flow
    Last Post: 10-01-2014, 10:25 AM
  2. Pipe Bending Procedures
    By praphulla.phirke in forum Mechanical Engineering
    Last Post: 07-13-2014, 05:22 AM
  3. Pipe Welding Procedures
    By SHEMYY in forum Mechanical Engineering
    Last Post: 05-12-2014, 10:52 AM
  4. Pipe welding procedures
    By vfq3481 in forum Mechanical Engineering
    Last Post: 10-26-2012, 02:59 PM
  5. Back off procedures & BP stuck pipe manual
    By oileruis in forum Drilling And Workover
    Last Post: 02-19-2012, 11:17 PM
