Please find the attached Excel Worksheet program which contain the following
Program Description
0 Conversion Factors
1 API - Determines oil API, density and molecular weight at any temperature
2 Water Properties: Density and thermal properties of water
3 Thermal Properties: Heat capacity, thermal conductivity and diffusivity of
fluid saturated rocks/and liquids
4 Viscosity of Liquid Mixtures & Emulsions
5 PVT: Determine Bo, Bw,Bg, GOR, Pb,compressibility, dead/live oil viscosity at reservoir temperature
6 Steam Tables
7 Heat of Combustion
8 Heat Conduction: erfc function
9 Hot Water Injection: Temperature away from injector
10 Steam Zone Volume
11 Steam Conformance
12 Oil-Steam Ratio
13 Combustion Parameters
14 Single Phase Pressure Drop in Pipeline
15 Wellhead Steam Rates and Pressure Drops
16 Waterflood Voidage Replacement Ratio
17 Bottomhole Pressure Determination from Acoustic Shot
18 Recombination at Separator
19 Residual Oil Saturation After Steamflood
20 Reserves
21 SAGD
22 Horizontal Wells
23 Thermal Casings
24 Wellbore Heatlosses
25 Reservoir Properties
26 Optimum Working Interest
27 Optimum Number of Drilling Locations and PDV
28 Success-Fail Model
29 Original-Gas-In-Place
30 Refinery Calculations
30.1 Petroleum Fractions
31 Relative Permeability
32 Slurry Viscosity
33 DST
34 Volumetrics
35 Engineering Economics
36 Sask Royalties
37 Alta Royalties
38 Oil Prices
39 OPEC and World Production
40 Progressive Cavity Pumps and Pumps (IPR)
41 Steam Distribution Systems
42 Minimum Miscibility Pressure & VAPEX
43 EOR Parameters
44 EOR Royalties
45 Tracers - Radioactive
46 Heavy Fractions
47 Mining
48 Production Facilities
49 Catalyst
50 Canadian Dollar
51 References and Assignments
