Page 1 of 2 1 2 LastLast
Results 1 to 12 of 22
Thread: Asme y14 drawing
    Asme y14 drawing
    DM2 - 04-03-2011 08:01 AM View Conversation Report
    Achmad,
    You had posted some information on ASME Y14 drawing standards:
    No ASME No Year Title
    1 Y14.1
    2 Y14.1M
    3 Y14.2
    4 Y14.3
    5 Y14.4M
    6 Y14.5
    7 Y14.5.1M
    8 Y14.5.2
    9 Y14.5M
    10 Y14.6
    11 Y14.7.1
    12 Y14.7.2
    13 Y14.8M
    14 Y14.13M
    15 Y14.18M
    16 Y14.24
    17 Y14.32.1M
    18 Y14.34
    19 Y14.35M
    20 Y14.36M
    21 Y14.38a
    22 Y14.40.0
    23 Y14.40.1
    24 Y14.40.2
    25 Y14.40.3
    26 Y14.40.4
    27 Y14.40.5
    28 Y14.40.6
    29 Y14.40.7
    30 Y14.40.8
    31 Y14.40.9
    32 Y14.40.11
    33 Y14.40.12
    34 Y14.40.15
    35 Y14.41
    36 Y14.42
    37 Y14.43
    38 Y14.100
    39 Y14 TECH REPT 4
    I'm not sure if you have those standards but if so, would you post them?
    HERE IS THE LINKS
    ASME Y14.1-1995.pdf 0.595 MB
    ASME Y14.1M-2005.pdf 0.504 MB
    ASME Y14.2 - 2008.pdf 2.083 MB
    ASME Y14.3-2003 Multiview & Sectionalview drawing.pdf 0.831 MB
    [link Point to another website Only the registered members can access] 2003%20Multiview%20%26amp%3B%20Sectionalview%20dra wing.pdf
    ASME Y14.4M - 1989.pdf 0.935 MB
    ASME Y14.5.1M - 1994 (R-2004).pdf 3.280 MB
    ASME Y14.5.2 - 2000.pdf 6.896 MB
    ASME Y14.5-2009.pdf 32.991 MB
    ASME Y14.5M - 1994.pdf 9.767 MB
    ASME Y14.6-2007.pdf 0.612 MB
    ASME Y14.7.1 - 1971.pdf 0.933 MB
    ASME Y14.7.2 - 1978.pdf 0.920 MB
    1 Y14.1 1995 Decimal Inch Drawing Sheet Size and Format
    2 Y14.1M 2005 Metric Drawing Sheet Size and Format
    3 Y14.2 2008 Line Conventions and Lettering
    4 Y14.3 2003 Multiview and Sectional View Drawings Revision of ANSI Y14.3 - 1975
    5 Y14.4M 1989 Pictorial Drawing
    6 Y14.5. 2009 Dimensioning and Tolerancing
    7 Y14.5.1M 2004 Mathematical Definition of Dimensioning and Tolerancing Principles
    8 Y14.5.2 2000 Certification of Geometric Dimensioning and Tolerancing Professionals
    9 Y14.5M 1994 Dimensioning and Tolerancing
    10 Y14.6 2007 Screw Thread Representation
    11 Y14.7.1 1971 Gear Drawing Standards - Part 1 for Spur, Helical, Double Helical and Rack Partial Revision of Y14.7-58
    12 Y14.7.2 1978 Gear and Spline Drawing Standards Part 2 - Bevel and Hypoid Gears
    13 Y14.8M 1996 Castings and Forgings
    14 Y14.13M 1981 Mechanical Spring Representation
    15 Y14.18M 1986 Optical Parts
    16 Y14.24 1999 Types and Applications of Engineering Drawings Revision of ASME Y14.24M-1989
    17 Y14.32.1M 1994 Chassis Frames - Passenger Car and Light Truck - Ground Vehicle Practices
    18 Y14.34 2008 Associated Lists
    19 Y14.35M 1997 Revision of Engineering Drawings and Associated Documents
    20 Y14.36M 1996 Surface Texture Symbols
    21 Y14.38a 2002 Abbreviations and Acronyms Revision and Redesignation of ASME Y1.1-1989; Addenda A-2002
    22 Y14.40.0 2002 Basic Rules for the Design of Graphical Symbols for Use in the Technical Documentation of Products Identical to ISO 81714-1:1999
    23 Y14.40.1 2002 Graphical Symbols for Diagrams, Part 1: General Information and Indexes
    24 Y14.40.2 2002 Graphical Symbols for Diagrams, Part 2: Symbols Having General Application
    25 Y14.40.3 2002 Graphical Symbols for Diagrams, Part 3: Connections and Related Devices Identical to ISO 14617-3: 2002
    26 Y14.40.4 2002 Graphical Symbols for Diagrams, Part 4: Actuators and Related Devices Identical to ISO 14617-2: 2002
    27 Y14.40.5 2002 Graphical Symbols for Diagrams, Part 5: Measurement and Control Devices ISO 14617-5
    28 Y14.40.6 2002 Graphical Symbols for Diagrams, Part 6: Measurement and Control Functions
    29 Y14.40.7 2002 Graphical Symbols for Diagrams, Part 7: Basic Mechanical Components
    30 Y14.40.8 2002 Graphical Symbols for Diagrams, Part 8: Valves and Dampers Identical to ISO 14617-8:2002
    31 Y14.40.9 2002 Graphical Symbols for Diagrams, Part 9: Pumps, Compressors , and Fans Identical to ISO 14617-3: 2002
    32 Y14.40.11 2002 Graphical Symbols For Diagrams, Part 11: Devices for Heat Transfer and Heat Engines Same as ISO 14617-11
    33 Y14.40.12 2002 Graphical Symbols for Diagrams, Part 12: Devices for Separating Purification, and Mixing
    34 Y14.40.15 2003 Graphical Symbols for Diagrams, Part 15: Installation Diagrams and Network Maps ISO 14617-15:2002
    35 Y14.41 2003 Digital Product Definition Data Practices
    36 Y14.42 2002 Digital Approval Systems
    37 Y14.43 2003 Dimensioning and Tolerancing Principles for Gages and Fictures
    38 Y14.100 2008 Engineering Drawing Practices
    39 Y14 TECH REPT 4 1989 Structural Language Format for Basic Shape Description
    REGULATION OF IFILEE.IT :
    Are there any download limits?
    • Our bandwidth is shared between all users, so at peak times it might get slow, beside our best effort guarantee we can not promise anything to guest and free users
    • Do note that speeds are fastest off-peak, between 24:00 and 12:00 GMT when there are alot of unused and wasted bandwidth.
    • Free registered accounts get faster downloads than Guest users
    • Download accelerators such as FlashGet are allowed
    • Please don't open more than 2 parallel connections per download
    • Each Download Ticket expires after 24 hours
    • Our servers are in USA and EU so the people in those countries should get the faster speeds in theory.
    • There are no download counters! and you can download all you want! Same as you could with mihd.net since 2006, though there is a CAPTCHA to stop automated requests if multiple downloads occur from the same location in short time.
    ASME Y14-8M,13M,18M,24,31,32,1M,34,34M,35M,36M.38A.rar 23.249 MB
    Thanks Achmad, you had a couple that I did not have, here are a few more...
    ASME Y14.41;2003 - Digital Product Definition Data Practices.pdf 4.538 MB
    ASME Y14.42;2002 - Digital Approval Systems.pdf 0.271 MB
    ASME Y14.43;2003 with 2005 Errata (R2008) - Dimensioning and Tolerancing Principles for Gages and Fixtures.pdf 2.777 MB
    ASME Y14.44;2008 - Reference Designations for Electrical and Electronics Parts and Equipment.pdf 1.067 MB
    ASME Y14.100;2004 - Engineering Drawing Practices.pdf 0.625 MB
    Guide to ASME Y14.5M;1994 - Geometric Dimensioning and Tolerancing for Mechanical Design.pdf 2.678 MB
    Manual of Engineering Drawing to British and International Standards 2nd Ed. 2004.pdf 5.769 MB
    Thank you Nabilia, you have helped me to upload the standard. Easier for me.
    To DM2, that's all we have. Enjoy it.
    ASME Y14- 40 SERIES.rar 7.027 MB
    Wooow, forgotten the last one.
    Y14 TECH REPT 4.pdf 3.99 MB
    Achmad and Nabilia
    Thanks ever so much for the Y14 standards. I've been off the list for a while and this thank you is late in coming...please accept my apologies.
    D
  10. hey hi..
    is not working
    can you please post it once again..
    I can not dowload Y14.6 2007 Screw Thread Representation file. Please post once again. Thank you.
  12. Re: Asme y14 drawing
    Hi Achmad,
    Thank you for posting the Links. But I think the links are dead and I am unable to download. I will appreciate if you can upload the files again.
    Jake
    ASME Y14 SERIES.rar 105.54 MB
  14. #11
    Jul 2013
    Jakarta-indonesia
    many thank Ahmad Nur Edin for the link...
    yanwarta
  16. #12
    Jul 2013
    Jakarta-indonesia
    yanwarta
  1. Replies: 7
    Last Post: 01-07-2016, 01:44 PM
  2. Alignment Drawing or General Arrangement Drawing?
    By abuufurqaan in forum Pipeline And Fluid Flow
    Last Post: 01-07-2014, 07:32 PM
  3. ASME Y14.35 - Drawing
    By Achmad Nur Eddin in forum Mechanical Engineering
    Last Post: 06-05-2013, 10:11 AM
