Results 1 to 7 of 7
Thread: ASTM standards latest edition only pls
    hi all
    I require the latest edition 2009/2010/2011 of the following standards
    pls upload if u have the latest edition of these
    A53/A53M-10. Standard specification for pipe—steel, black and hotdipped, zinc-coated,
    welded, and seamless.
    A105/A105M-10. Standard specification for carbon steel forgings for piping applications.
    A106. Standard specification for seamless carbon steel pipe for hightemperature service.
    A181/A181M. Standard specification for carbon steel forgings, for general-purpose piping.
    A182/A182M. Standard specification for forged or rolled alloy-steel pipe flanges, forged fittings, and valves and parts for high-temperature service.
    A193/A193M-. Standard specification for alloy-steel and stainless steel bolting materials for high-temperature service.
    A194/A194M. Standard specification for carbon and alloy steel
    A216/A216M-93Standard specification for steel castings, carbon,suitable for fusion welding, for high-temperature service.
    A217/A217M-. Standard specification for steel castings, martensiticstainless and alloy, for pressure-containing parts, suitable for hightemperature service.
    A234/A234M- Standard specification for piping fittings of wrought carbon steel and alloy steel for moderate- and high-temperature service
    A312/A312M- Standard specification for seamless and welded austenitic stainless steel pipes.
    A320/A320M. Standard specification for alloy-steel bolting materials for low-temperature service.
    A333/A333M. Standard specification for seamless and welded steel pipe for low-temperature service.
    A334/A334M-Standard specification for seamless and welded carbon and alloy-steel tubes for low-temperature service
    A335/A335M- Standard specification for seamless ferritic alloy-steel pipefor high-temperature service.
    A350/A350M-. Standard specification for carbon and low-alloy steel forgings, requiring notch toughness testing for piping components
    A351/A351M-. Standard specification for castings, austenitic, austeniticferritic (duplex), for pressure-containing parts.
    A352/A352M- Standard specification for steel castings, ferritic and martensitic, for pressure-containing parts, suitable for low-temperature service.
    A403/A403M-. Standard specification for wrought austenitic stainless steel piping fittings.
    A420/A420M. Standard specification for piping fittings of wrought carbon steel and alloy steel for low-temperature service
    A515/A515M Standard specification for pressure vessel plates, carbon steel, for intermediate- and higher-temperature service.
    A516/A516M Standard specification for pressure vessel plates, carbon steel, for moderate- and lower-temperature service.
    A671-. Standard specification for electric-fusion-welded steel pipe for atmospheric and lower temperatures.
    A672- Standard specification for electric-fusion-welded steel pipe for high-pressure service at moderate temperatures.
    A691. Standard specification for carbon and alloy steel pipe,electric-fusion-welded for high-pressure service at high temperatures
  3. Please upload if you have the above standards.
    Thanks a million.
    Identical A/SA (ASTM/ASME) sds you can find in ASME II Part A ed. 2010. These stds are in forum links
  6. Re: ASTM standards latest edition only pls
    we are maufacturer of steel pipe , pipe fitting , flange
    Any more requirement , contact me :qcggamy@hotmail.com
    Mobile phone:86-18931788358
  7. Re: ASTM standards latest edition only pls
    Does Any Body Have ASME Section IX..
    kinldy send to harishchopr@yahoo.com
    Thanks in advance
    Take a look
  1. Replies: 13
  2. ASTM A6 and ASTM A36 Latest Versions
    By theglobalist2003 in forum Mechanical Engineering
    Last Post: 02-19-2019, 08:32 AM
  3. ASTM-A312 latest version
    By thiagorcollis1 in forum Mechanical Engineering
    Last Post: 10-29-2014, 09:34 PM
  4. ISA Standards (Latest edition is required)
    By Sajid Ali Khan in forum Instrumentation & Control
    Last Post: 12-07-2013, 05:21 PM
  5. REQUEST : API Risk-Based Inspection (RBI) Standards (Latest Edition)
    By simpanbuku in forum Mechanical Engineering
    Last Post: 05-31-2013, 09:01 PM
