IF ANYONE CAN CONTRIBUTE HOW WORK WITH CAPILLARY PRESSURE IN NATURALLY FRACTURED RESERVOIRS APPLIED TO SIMULATION MODELS.
SPECIALLY FOR CREATE SW FUNCTIONS.
THANKS
OPINIONS OF THIS TECHNIQUE:
Incorporating Capillary Pressure, Pore Throat Aperture Radii, Height above Free-Water Table, and Winland r35 Values on Pickett Plots
Roberto Aguilera1
1 Servipetrol Ltd., 736 6th Avenue SW, Suite 1640, Calgary, Canada T2P 3T7; aguilera@servipetrol.com
Roberto Aguilera is president of Servipetrol Ltd. in Calgary, Canada. He has an undergraduate degree in petroleum engineering from the Universidad de America in Bogota, Colombia, and a master's degree and Ph.D. in petroleum engineering from the Colorado School of Mines. He was an AAPG instructor on the subject of naturally fractured reservoirs from 1984 through 1996. He received the Outstanding Service Award from the Petroleum Society of the Canadian Institute of Mining, Metallurgy and Petroleum Engineers (CIM) in 1994. He is a Distinguished Author of the Journal of Canadian Petroleum Technology (1993 and 1999) and a Society of Petroleum Engineers Distinguished Lecturer on the topic "Naturally Fractured Reservoirs" for the 2000-2001 season. He has developed various methods that have been published in leading journals of the oil industry. He has authored and been a contributor to various books, including Naturally Fractured Reservoirs (PennWell, 1980 and 1995), The Technology of Artificial Lift Methods (PennWell, 1984), Horizontal Wells (Gulf Publishing, 1991), and Determination of Oil and Gas Reserves (Petroleum Society of CIM Monograph 1, 1994).
Methods are presented for incorporating capillary pressure, pore throat aperture radii, height above the free-water table, and Winland r35 values on Pickett plots. The techniques involve the use of log-log plots of effective porosity vs. resistivity combined with empirical equations for calculating capillary pressure written as a function of permeability, porosity, and water saturation.
I show that a crossplot of porosity vs. true resistivity (in some cases apparent resistivity or true resistivity affected by a shale group) should result in a straight line for intervals with constant capillary pressure and constant pore throat aperture radii. Key advantages of the proposed methods are (1) the capillary pressure at any point on the Pickett plot is consistent with porosity, permeability, and water saturation at that particular point; (2) the value of Rw does not have to be known in advance, provided that the reservoir contains some water-bearing intervals; and (3) core data are not essential, although it is strongly recommended to have cores to properly calibrate the equations presented in this article. If capillary pressures from cores are available, it is possible to estimate the value of Rw even if there are not water-bearing intervals in the reservoir.
Pore throat aperture radii (r35) values computed using the empirically derived Winland equation compare reasonably well with pore throat aperture radii (rp35) calculated from techniques presented in this article. This is significant because the data sets used to establish these empirical equations come from different areas, different reservoirs, and different lithologies and were evaluated independently at different times. A mathematical relationship is developed between Winland r35 values and the pore throat aperture rp35 presented in this article.
The methods are illustrated using two case histories. The first one is a Gulf Coast high-porosity sand-shale sequence. The second is a limestone oil reservoir from the Lansing Kansas City formation.
The integration of permeability, capillary pressures, pore-size classes, and geometry of the pores on a log-log graph of porosity vs. resistivity makes the Pickett plot one of the most formidable formation evaluation tools yet devised.
