Page 1 of 4 1 2 3 ... LastLast
Results 1 to 12 of 39
Thread: WRC Bulletins
    WRC Bulletins
    These are all I have, please contribute others here....
    WRC Bulletin 107 Oct. 2002 Local Stresses in Spherical and Cylindrical Shells Due to External Loadings.pdf 54.263 MB
    WRC Bulletin 198 Sept. 1974 Secondary Stress Indices for Integral Structural Attachments to Straight Pipe - Stress Indices at Lug Supports on Piping Systems.pdf 6.082 MB
    WRC Bulletin 297 Sept. 1987 Local Stresses in Cylindrical Shells Due to External Loadings on Nozzles-Supplement to WRC Bulletin No. 107 Rev.1.pdf 66.443 MB
    WRC Bulletin 329 Dec. 1987 Accuracy of Stress Intensification Factors for Branch Connections.pdf 6.013 MB
    WRC Bulletin 417 Dec. 1996 Design Guide to Reduce Potential for Vibration Caused by Fluid Flow Inside Pipes-Review and Survey.pdf 11.864 MB
    WRC Bulletin 429 Feb. 1998 3D Stress Criteria Guidelines for Application.pdf 41.497 MB
    WRC Bulletin 449 Feb. 2000 Guidelines for the Design and Installation of Pump Piping Systems.pdf 15.611 MB
  3. thanks!
    Does any one have the newest WRC 537 which replaced WRC 107? If you have, could you help to share with us? Thanks in advance!
    Thank you
  6. Thanks a lot !
    Quote Originally Posted by bestleemh View Post
    thanks!
    Use of FEA, for example NozzlePro PRG, is more advance way for this cases. If You have specific problem, send me at yuri.morozov@yahoo.com
    Oct 2008
    The Netherlands
    Blog Entries
    14
    Thanks for putting these WRCs
    Dear Nabilia,
    Thankyou Very much friend for your wonderful collections.
    Thanks!!!!
  12. Quote Originally Posted by Yuri47 View Post
    Thanks for your afford. Yes, FEA is adopted for this case. But for pressure vessel, in most cases WRC 537 is applied.
    Thanks. Can any one share WRCB-537?
  14. #11
    As the preface of WRC 537 said the WRC 537 seen as 2010 edition of WRC 107, give all curves and figures with numerical approach formula, and correction some minor errors.
    And WRC would not published WRC 107, only WRC 537. So WRC 107 didn't be withdrawn, its still exist and valid.
  16. #12
    Does any one have the newest WRC 537 ?
    thanks in advance!
    AMinati
  1. ACI - Field Guide to Concrete Repair Application Procedures (RAP) Bulletins 1-9
    By Nabilia in forum Civil & Structural Engineering
    Last Post: 11-29-2016, 10:20 PM
  2. WRC Bulletins
    By ani_dat in forum Mechanical Engineering
    Last Post: 08-27-2013, 10:07 AM
  3. WRC Bulletins
    By ambhad in forum General Engineering
    Last Post: 04-28-2013, 06:40 PM
