Thread: Water Hammer & Slug Force
    Post Water Hammer & Slug Force
    Dear Friends,
    I am analyzing a 20” condensate blow down line using CAESAR II software.
    From two vessels, two 6” condensate line outlets connects with two separate control valve (ESDV) arrangement and this line further expands as 12”. This both 12” line after 10m connects with a 20” blow down header.
    During shutdown both esdv is supposed to open fully to depressurize the two vessels (approximately in 15 min duration). Control valve allows 4 bar at the downstream.
    My question is,
    1. Is there a chance of water hammering effect in the downstream (12” & 20” line) of valve.
    2. Or because of the sudden pressure reduction near to the valve is there any chances of slug flow.
    3. Is it Possible for Both Water hammer & Slug force ?
    Without considering both (water hammer & slug force) system passes. Kindly throw some light on this issue. Thanks in advance.
    Oct 2008
    The Netherlands
    Blog Entries
    14
    I believe , for water hammmer is to start with the rough formula of Joukovsky , It gives a good approach for estimating the surge pressure , which you have to add onto your design pressure , to select the correct flange rating. You have a lot of sites for that , but I can estimate it yourself if you know the speed, density , thickness , modulus of young
    With Caesar it is a dynamic issue and you will tret the mode shape and and see ultimately where to put your axial supports ; on which you will have hignloads
    suggest you go to coade site = coade.com
    Also Caesar has a worked example , I Suggest to study it
  1. Water hammer
    By lgb in forum Instrumentation & Control
    Last Post: 03-13-2014, 03:31 PM
  2. Water Hammer & Slug Force
    By raam in forum Petrochemical
    Last Post: 06-08-2012, 09:33 PM
  3. Water Hammer
    By junqueira in forum Pipeline And Fluid Flow
    Last Post: 02-16-2012, 10:48 PM
  4. Article: Water Hammer & Slug Force
    By raam in forum Home Articles
    Last Post: 03-29-2011, 06:03 AM
