Results 1 to 11 of 11
Thread: SAGD Data Files for CMG STARS needed.
  1. Exclamation SAGD Data Files for CMG STARS needed.
    Hello guys,
    If anybody here has access to any SAGD based Data Files on CMG STARS or otherwise would you please be kind enough to upload it and post the link to download the files. This would be a great help to a student in need, and I would appreciate this a lot.
    Please consider this request and post the information.
    Thanks for all the help
  3. Hello guys,
    If not the above, at least can somebody here provide me with a heavy oil field data file so that I can change it to my specifications and carry out the necessary work ? Please let me know.
    Cheers
  5. Even Petrel based Heavy Oil Data Files are hugely appreciated. If not please give me the details of the heavy oil field and I will try and build a model myself. Please let me know.
    Cheers
  6. Here you go - two folders with examples:
    hrw -
    spe -
    hrw folder containes following examples:
    sthrw001.dat:
    title1 'STARS Test Bed No. 33'
    title2 'Gravity Drainage Run Sequence'
    title3 'Horizontal Wells Modelled with Discretized Wellbore Option'
    sthrw005.dat:
    title1 'STARS Test Bed No. 63'
    title2 'Steam Trap Well Control Option Illustration'
    sthrw006.dat:
    title1 'STARS Test Bed No. 64'
    title3 'Horizontal Discretized Wellbore Inside Hybrid Grid'
    sthrw007.dat:
    title1 'STARS Horizontal Well Template #7'
    title2 'Steam Injection with 26 Wells Including 3 Horizontal Producers'
    title3 'Variable Top, 2 Regional Aquifers, Actual 12-Year History'
    sthrw008.dat:
    title1 'STARS Horizontal Well Template #8'
    title2 'LIAOHE SAGD PROJECT - PHASE 3'
    title3 '3D DISCRETIZED WELLS WITH DIP'
    sthrw009.dat:
    title1 'STARS Horizontal Well Template #9'
    title2 'Single Discretized Wellbore Inside Hybrid Grid (SWSAGD)'
    title3 '800-metre Well Model in Typical Alberta Reservoir'
    spe folder containes following examples:
    stspe001.dat:
    title1 'STARS Test Bed No. 6'
    title2 'Fourth SPE Comparative Solution Project'
    title3 'Problem 1A: 2-D CYCLIC STEAM INJECTION'
    stspe002.dat:
    title1 'STARS Test Bed No. 7'
    title3 'Problem 2A: Steam Flood with Dead Oil'
    stspe003.dat:
    title1 'STARS Test Bed No. 8'
    title3 'Problem 3A: Steam Flood with Three-Component Live Oil'
  7. @Kochichiro,
    Thanks a lot for help with these files. I appreciate this a lot. The issue is, these files are already in the CMG Files list and I can't seem to make any changes to these files as this will change the discrete-ised grids. So any ideas how I can edit these files to my specs ?
    Cheers
  9. Re: SAGD Data Files for CMG STARS needed.
    Some members asking me to re-upload data, so here it is -
  10. Re: SAGD Data Files for CMG STARS needed.
    thank u so much!
    do anyone know if there are any other source where i can have dat files for CMG STARS?
    thank you in advance
    Try to ask CMG directly. They might support your academic interests.
    I could not access to the megaupload links. They did not work. Can you please send me the files. I need them so urgently. Thank you so much
    Thanks for the link, unfortunately I can't access them.
    THanks for your help, need to get some guides on how to use STARS effectively
    Thanks so much
  14. #11
    Cool Re: SAGD Data Files for CMG STARS needed.
    The data has been re-uploaded here:
    Hope that helps!
  1. CMG Stars Simulator Needed
    By dd2112 in forum Engineering Programming
    Last Post: 10-28-2016, 07:58 PM
  2. HELP Needed urgently plzzzz....SAGD
    By pank27 in forum Reservoir
    Last Post: 04-01-2011, 04:41 PM
