Hi friends
i need to make a VFPi tables for simulation..the question is: is there any way to export that (VFP) file from pipesim ?
Hi friends
dear Ivan
i start use pipesim recently and iam facing the same issue.
for sure there is way to export VFP table to Eclipse,
but how i don't know yet.
if i get new information i will let you know.
best regards,
dear friend
i tried to find a way but nothing, finally i did some analysis in VFPi in eclipse..but it is very confusing when you are dealing with gas-condensate reservoirs which is my case..have you tried prosper?..is there any solutions for that problem ?
regards
friend,
i reached to the answer in Pipesim.
here is general workflow to prepare pipsim VFP table:
1-setup tab=>Units
2-Setup tab=>black oil or compositional and set up your pvt data, correlations, observed data for caliberation.
3-setup tab=>flow correlations and select the VFP and horizontal flow correlation that will be used in the model.
4-Data tab=>load/add measured data survey.
5-Operations tab=>pressure/temperature profile and nodal analysis if you need.
6-Operation tab=>flow correlations comparison, to compare different correlations with your observed data.
7-Operation tab=>data matching to match the observed data.
8-Operation tab=>reservoir tables, where you enter ranges of rates, GOR, WCut and WHFP and run the model to creat reservoir tables.
one of the output of reservoir table file with extension (.t01) this is the VFP table to eclipse or any simulator you select.
keep in mind that this VFP table is not including well name but it categorized by table number and in Eclipse\schedule section\WCONPROD keyword you set the VFP table for the well.
i hope this help,
regards,
sorry i forget some thing,
after flow correlations comparison and data matching you have to back to Setup=>flow correlation and select the correlation that best fit your observed data then move to reservoir tables.
regards,
Hi Forum,
Pipesim 2018 full working now with me. Ready to share.
Some other applications like Eclipse 2018, Kappa 5.2, CMG 2018 and ... are also available.
I will be happy if you interested in exchange. follow me on this address:
tnudefski@gmail.com
