Thread: Infinite Acting Radial flow in Coventional Decline Curve Analysis (DCA)
    Aug 2010
    Jakarta, Perth & Kuala Lumpur
    Guys,
    Okay for your academics out there here is a real technical question.......
    We know that DCA is inapplicable for Infinite Acting Radial flow (i.e. non stabilized flow/transient/non pseudosteady steady state (PSS) flow).
    Can anyone tell me how this violates the analytical solution proposed by Arps i.e. the solution to the differential generalized hyperbolic equation?
    My understanding of PSS, is that under pseudosteady state flow, the difference between the flowing wellbore pressure and the average reservoir pressure in the drainage volume is constant.
    Thus one of the boundary conditions to Arps solution to the differential generalized hyperbolic equation, appears to be constant pressure. Thus non PSS would appear to violate the boundary conditions necessary to solve the differential generalized hyperbolic equation.
    Is this correct?
    Thanks Guys, much appreciated!
    Chee Koh Peh!
    Nov 2008
    Australia
    Sorry - I'd have to sit down with pencil and paper to really think it through, and don't have the inclination right now ;-)
    What I CAN offer is that there has been some recent work (I believe if not in a paper already, soon to be in one from Fekete) that basically says a decline exponent of 2.0 (where 'normal' decline parameters should not go over 1.0) is a close approximation to transient flow. In fact they are using this to help characterize tight gas declines - from assume drainage radius and perm/poro they calculate time to reach boundary against which they use exponent of 2.0 until boundary 'seen' then something less than 1 (ie 0.6) after this
    Hope this helps.
    Heh ! heh ! Cheeky...I like it. A simple way around is RTA.
  1. Decline Curve Analysis Software
    By upstream in forum Reservoir
    Last Post: 10-25-2013, 03:25 PM
  2. Decline Curve Analysis (DCA)
    By capo8888 in forum Oil And Gas Production
    Last Post: 07-30-2013, 05:39 PM
  3. Traditional Decline Curve Analysis
    By ameer in forum Reservoir
    Last Post: 12-19-2012, 10:37 PM
  4. Decline curve analysis
    By bayan in forum Reservoir
    Last Post: 11-13-2012, 01:56 PM
  5. Decline curve analysis DCA
    Last Post: 03-16-2012, 07:09 PM
