Results 1 to 11 of 11
Thread: Guidelines for Design Solutions for Process Equipment Failures
    Guidelines for Design Solutions for Process Equipment Failures (Center for Chemical Process Safety "Guidelines" series)
    Product Description
    While there is no "perfect" solution or absolute zero risk, engineering design can significantly reduce risk potential in the CPI. In Guidelines for Design Solutions to Process Equipment Failures, industry experts offer their broad experience in identifying numerous solutions to the more common process equipment failures including inherent safer/passive, active, and procedural solutions, in decreasing order of robustness and reliability. The book challenges the engineer to identify opportunities for inherent and passive safety features early, and use a risk-based approach to process safety systems specification. The book is organized into three basic sections: 1) a technique for making risk-based design decisions; 2) potential failure scenarios for 10 major processing equipment categories; and 3) two worked examples showing how the techniques can be applied. The equipment categories covered are: vessels, reactors, mass transfer equipment, fluid transfer equipment, solids-fluid separators, solids handling and processing equipment, and piping and piping components. Special Details: Hardcover book plus 3.5" diskette for use in any word processing program with design solutions for use in PHAs.
    Thank you!
    Oct 2008
    Petrol City, Ca Coast
    thank you
  6. Thanks for sharing this with us
    I am too late
    Links are dead
    Please repost if possible
    Thanks in advance
    CCPS Guidelines For Design Solutions For Process Equipment Failures (Aice, 1998).pdf
  10. Nabilia, thank you.
    Thank you very much sir.
    Thanks a lot for your prompt reply and for the link
    Re: Guidelines for Design Solutions for Process Equipment Failures
    please share this book.....
    mahendrapal.rathore@gmail.com
  14. #11
    please share this book saraswathula@rediffmail.com
    thanx in advance
  1. UniSim® Design Suite R430 - Honeywell Process Solutions
    By checherni in forum Petroleum Refining
    Last Post: 09-27-2015, 09:22 AM
  2. Guidelines for Design Solutions for Process Equipment Failures
    Last Post: 01-22-2014, 11:26 PM
  3. Guidelines for Design Solutions for Process Equipment Failures
    By Mohamed in forum Safety And Environment
    Last Post: 08-03-2012, 12:49 PM
  4. searching: Solutions to Equipment Failures
    By sumon emam in forum Mechanical Engineering
    Last Post: 07-26-2012, 03:13 PM
  5. Process Design Guidelines
    By gogisu in forum Oil And Gas Process
    Last Post: 09-07-2009, 10:12 AM
