Results 1 to 10 of 10
Thread: Article: Sea Water - Pipe Material for Fire Fighting System ?
    You can view the page at
    Once I worked in the design of a fire fighting pipe network systemg usin higly corrosive water from Maracaibo Lake, where corrosion is high due to dissolved oxigen. We propose internal concrete lined pipes that was normally use for that task.
  5. Hi, as GUSGON said concret would be an alternative, I may suggest use a internal coating such a ARC composite, In an importan Venezuelan Refinery Amuay - Cardon in the 90 th the sea water system was lined with concret but the corrosion was very strong, the solution was replaced the concrete for a composite called ARC S2 this is the reference
    The person in the photo about inspection inside the elbow was Mr Carlos Paz, this ia a reference of a solution
  6. This is another reference
    Nov 2010
    Tehran, Iran
    FRP (GRP) is the best choice.
  9. Hi All,
    I have experienced, once, in the petrochemical Plant.
    using HDPE for sea water to be used for fire fighting and water supply for the cooler.
  10. Hi all,
    in my opinion the best choice is GRP pipe. it can be operate without problem of corrosion and erosion.
    See the following site for CR4:
  12. GRE from nov products or ameron is ok for heavy corrosion service.
  13. After many years of building pipelines then turning to designing them, I have had many bad experiences with GRP ofr similar as this pipe has no structural integrigy and relies upon the backfill to be of the highest order around it, if the backfill moves at all the pipe will leak or burst.
    I have also seen many concrete lined fire mains that operate with sea water become collinders with 10 years
    The choice for me has to be HDPE the joint fabrication thesedays is computer controlled so that is good and it is not suseptable to corrosion
    the only chioce
  1. Fire fighting fire water pump design
    By aniket00786 in forum Safety And Environment
    Last Post: 06-13-2014, 07:31 AM
  2. Article: Offshore fire fighting
    By Xrusa in forum Home Articles
    Last Post: 05-11-2013, 06:45 PM
  3. Article: Fire Fighting SIL study
    By josefreitas in forum Home Articles
    Last Post: 10-02-2011, 04:20 PM
  4. Article: Fire Fighting SIL study
    Last Post: 09-25-2011, 10:23 AM
  5. Sea Water - Pipe Material for Fire Fighting System ?
    By uzbarry in forum Safety And Environment
    Last Post: 02-09-2011, 08:15 AM
