Results 1 to 6 of 6
Thread: Sea Water - Pipe Material for Fire Fighting System ?
    Exclamation Sea Water - Pipe Material for Fire Fighting System ?
    Can someone please advise what Pipe Material(s) can be used in Fire Fighting Systems when the water source is somewhat of SEA WATER type??
    We have to cope up with Corrosion and Erosion both, and "Erosion" can be the more deteriorating factor for the pipe material!
    UB
    In offshore platform normally use GRP or CuNi for firewater protection piping.
    Dear Suchart,
    thank you so much for the reply, can we use GRP for a pressurized FF line?
    or we have to plan it in a way that the lines should be pressurized in case of emergencies or real fires only?
    regards,
  6. Quote Originally Posted by suchart View Post
    dear collegues, just consider that plastic material in offshore application show low resistance when exposed to fires and explosions events: survivability of such an emergency system should be carefully assessed in this case.
    Typically GRP is used in onshore FF systems for buried pipes, whilst Cu-Ni alloy is suitable for marine applications.
    GRP pipe can use as a ring main for wet system and branch line for dry system can used maximum design pressure of pipe around 16 barg but not limit depend on manufacturer.
    thank you very much for the replies!
  1. Fire fighting fire water pump design
    By aniket00786 in forum Safety And Environment
    Last Post: 06-13-2014, 07:31 AM
  2. Replies: 2
    Last Post: 03-14-2013, 08:34 AM
  3. experience in fire water system software
    By camiqmex in forum Safety And Environment
    Last Post: 08-12-2011, 07:36 AM
  4. Replies: 9
    Last Post: 05-16-2011, 02:49 PM
  5. Fire Fighting Pump
    By ibnu.zaenal in forum Safety And Environment
    Last Post: 02-10-2010, 12:39 PM
