Hello guys, I am needed to calculate Joule-Thompson coefficient for reservoir gas. I have tuned EoS for this gas, so I can generate Z vs Pressure under constant T and vice versa plots, I also have specific heat capacity function so I can generate it for any pressure or temperature.
So, the question is how I can calculate Joule-Thompson coefficient, what plots should I generate and how I must use the data. Also, under which conditions I must perform the calculation – constant pressure with changing temperature or changing pressure with constant temperature.
I completely lost in this subject, so it would be nice if someone can help me out.
