Results 1 to 6 of 6
Thread: Isobar map
    Isobar map
    Please any body tell me how to prepare Isobar map of layer by layer of reservoir., I have different layer pressure in few wells. but every layers having different pressure in different depth.
    Nov 2008
    Australia
    You can make maps from properties under operations tab of the property in Petrel, simply filter by layer, make map, step down the next layer and repeat
    You can then set properties on the created maps to display contour lines for your isobar lines
    Jan 2009
    ALA, KZ
    In petrel if you want vertical slicing
    use following formula
    temp_pressure=if(k=4,pressure,U)
    where
    temp_pressure - new pressure property
    pressure = your initial pressure property
    k is k index of your array
    so what it will do is creating property of exact k index so you do not need to use filter
    then you can make map of the pressure for any layer you want
    And then you can write the macro which will create all maps on the fly - but this is other story my friend
    Jan 2009
    ALA, KZ
    Forgot one important thing
    Do not forget wight you pressure over pore volume if you will build maps for more than 1 layer
    and wight your pressure over pore volume if you will calculate av pressure of the layer
    I dont have any software so I will do manually.... Sir How to calculate Average pressure of individual well at same datum plane in single layer of reservoir. please guide me.......thanks for advice,
    Jan 2009
    ALA, KZ
    What input data you have
  1. Article: building Pressure Map or Isobar Map
    By anprax in forum Home Articles
    Last Post: 05-13-2013, 01:18 AM
  2. building Pressure Map or Isobar Map
    By anprax in forum Geology & Exploration
    Last Post: 05-11-2013, 10:15 AM
