Results 1 to 6 of 6
Thread: Reservoir Tops
    Reservoir Tops
    I need to make a reservoir in shape of a dome, I was wondering how do i go about it.
    I mean how do i give the tops to it.
    Is a perfect semi circle with a radius of 3000 ft.
    Any ideas ?
    Nov 2008
    Australia
    Furnish me the following and I'll generate with a simple spreadsheet for you - I made it at work, so cannot really make it public
    Desired Grid Dimensions: i x j x k
    Block Lengths: X x Y x Z (ft or m)
    Z Relief At crest: ft or m
    Depth at center of crest cell: ft or m
    Ellipse Fitting
    At ?? ft from center in I direction
    I Dip is ?? ft/1000ft
    HI vinomarky,
    I am afraid I have nothing of the data that you have asked. I was trying to mimic the reservoir design, see attachment, i wanted to learn how to make the dome type reservoir. I am just assuming that it is a perfect semi circle with 3000ft radius.
    I am sorry that I have no data to give it.
    Thank you for your reply.
    Quote Originally Posted by vinomarky View Post
    Ellipse Fitting
    Nov 2008
    Australia
    Looking at the pdf, my sheet doesn't really make that geometry anyway - its more designed for discrete thickness anticline rather than solid semi-bubble type geometry
    You might want to simply consider starting with a cube grid, and setting PORO to zero above the bubble - some reasonably simple spreadsheet math to define sphere surfaces would do the trick
    Hey Vino,
    I wish I knew how to do that too, I made a cubic.....but failed miserably on the spreadsheet maths.
    Nov 2008
    Australia
    The equation of a sphere, centered at point x0, y0, z0 of radius R is;
    (x-x0)^2 + (y-y0)^2 + (z-z0)^2 = R2
    So create your cube, cycle through each of the i's and j's of each layer, substituting in the corresponding mid-block x, y and z's into the above equation to solve for R2
    If the R2 is less than your radius^2, then set porosity = your desired poro. If R2 is greater than your radius^2, then set porosity = zero
  1. OpenWorks owx well tops to Petrel Import - Help
    By deepesttins in forum Geology & Exploration
    Last Post: 12-12-2013, 04:24 PM
  2. Reservoir
    By zangthanh in forum Reservoir
    Last Post: 08-12-2013, 07:46 PM
  3. about reservoir
    By selmagis in forum Reservoir
    Last Post: 06-20-2013, 03:29 AM
  4. Replies: 0
    Last Post: 05-04-2010, 10:05 AM
  5. tight gas reservoir
    By umair_865311 in forum Reservoir
    Last Post: 12-20-2009, 11:24 AM
