i install pipesim 2003 and olga 2000 on my PC but when i try to run flow correlation matching by Pipesim using OLGA correlation i get the following error
It means that the version of pipesim 2003 you have doesnt have the Olga steady state correlations.tHere are a couple of correlations that are not standard with pipesim e.g some bp/shell wax correlations
Dear Ibro,
thanks for your reply but i install Olga 2000 on my PC also , is there any bridge between pipesim 2003 and olga 2000 or i must have separate license to run Olga steady state correlations through pipesim2003
THere is no bridge. Olga sells its steady state correlations to other steady state hydraulic software vendors to use with their software eg pipepim and petroleum experts.The two softwares do not run together. You can try to run steady state simulations in olga 2000 with the correlation.I will check if my version of pipesim 2003 has the olga correlation and if it has i will upload
Dear Ibro,
I hope if you check your pipesim if it have OLGA correlation , i need to carry out Compression between correlations using pipesem and one of this correlation is Olga
Assalamu'alaikum Mr Muhammad Al Hagar. please find the ***** file to siolve Your problem at this site
salam
I'm looking for a real project realased by pipesim or olga. please can you send a pipesim file (if it's possible with description of a project)
my adress mail is oth_merkak@hotmail.com
baraka allah fikoum
please help me to install olga 2000
