Results 1 to 6 of 6
Thread: Design of Pressure Vessel at Sub zero Design Temperature
    As per ASME Sec-VIII Div 1, Any Specific class or requirement for design of pressure vessel which has a sub zero design temperature. Pls help me
  3. Quote Originally Posted by Sriram_be View Post
    Sriram_be,
    There is no such pressure vessel class in ASME VIII Div.1 as you have in Australian or some European pressure vessel codes.
    If you want to design a pressure vessel for low temperature service, impact test may be required for materials and WPS/PQR for some components.
    If the materials used in the pressure vessel are carbon and low alloy steel have a look at Part UCS paragraph UCS-66. For high alloy steels (including stainless steels), refer to Part UHA paragraph UHA-51.
    Cheers,
    Thank Ali
    Sriram
  6. Requirements for impact test are first covered in UG-20(f) of ASME Sec VIII Div 1. There you can get exemptions up to -20F if you comply with all the requirements. Othervise you have to follow the provisions given in UCS-66, UCS-67 & UCS-68 if dealing with Carbon & Low Alloy Steels and UHA-51 if dealing with Stainless steels
  7. sdddddddddddddddddddddddddddddddddd
  9. Sriram_be. .. the materials of vessels construction have a range of working temperatures, for example, and you will have to chech it, a steel SA-576 Gr.70 works between -20&#186;F and 200 &#186;F. This is just an example, the correct data will be found at the norm ASME
  1. Replies: 31
    Last Post: 08-04-2017, 07:00 PM
  2. Replies: 0
    Last Post: 06-27-2013, 07:25 PM
  3. Replies: 0
    Last Post: 06-27-2013, 07:22 PM
  4. Pressure Vessel Design - Consideration of Pressure Thrust
    By akaujalgikar in forum Oil And Gas Process
    Last Post: 06-03-2013, 11:33 AM
  5. Design pressure & Temperature for pumps
    By ravisasi in forum Safety And Environment
    Last Post: 09-25-2009, 06:43 PM
