Thread: Field devices location
  1. Field devices location
    Hi
    How to make field devices location drawing?
    Could you please send to me any documentation regarding making field devices location dwg ?
    Thanks in advance for your help
    Jun 2008
    Karachi, Pakistan
    Dear Alex,
    Is your query related to a) Drafting of Field Instruments Drawings or b) Comprehensive Engineering of Field Instrmentation.
    In case of "a" you can use Autocad with Addon for Instrumentation or Interplant Smart Plant Instrumentation etc.
    However in case your problem pertains to b, then the approach is quite complex and requires competency of many areas of Instrumentation Design ans Engineering. You should atleast have the following in your hands to start the work i) Site Plot Plan. ii) Piping Plan, iii) Process Equipment Layout, iv) Main cables routes civil structures, v) Instrument Air Supply Layout, vi) Control Room/Equipment Layouts, vii) Instrument Design Specifications, viii) P&IDs, ix) Piping Isometrics, x) Instrment Schedules etc. All these drawings and specifications will determine the suitable locations/elevations of Instruments.
    Sajid Ali Khan.
  1. EN 13155 - Lifting devices
    By QuimKouto in forum Mechanical Engineering
    Last Post: 01-11-2018, 04:43 PM
  2. Pressure Relief Devices
    By OMID1351 in forum Oil And Gas Process
    Last Post: 05-17-2017, 11:07 AM
  3. Pressure Relief Devices
    By vfq3481 in forum Mechanical Engineering
    Last Post: 08-14-2013, 11:52 AM
  4. Oil well location
    By tumba in forum Geology & Exploration
    Last Post: 10-29-2012, 10:10 AM
