Product Description
The Engineers’ Guide to Pressure Equipment incorporates both the technical and administrative aspects of vessel manufacture and use, introducing the basic principles of pressure equipment design, manufacture, quality assurance/inspection and operation during its
working life. Engineering data from a wide range of sources is included. The author guides the reader through the most commonly used current and recent pressure vessel codes and standards.
The Engineers’ Guide to Pressure Equipment is an invaluable reference for engineers, technicians and students with activities in the pressure equipment business.
COMPLETE CONTENTS:
Websites: Quick reference
Pressure equipment types and components
Basic design
Applications of pressure vessel codes
Manufacture, QA, inspection and testing
Flanges, nozzles, valves and fittings
Boilers and HRSGs
Materials of construction
Welding and NDT
Failure
Pressure Equipment
Directives and legislation
In–service inspection
References and Information Sources.
Synopsis
Including engineering data from a wide range of sources, "An Engineer's Guide to Pressure Equipment" provides an essential introduction to the technical and adminstrative aspects of vessel manufacture and use, covering the basic principles of pressure equipment design, manufacture, quality assurance/inspection, and operation during its working life. The author competently guides the reader through the most commonly used current and recent pressure vessel codes and standards. Pressure equipment has been subjected to an iterative development process that now makes it one of the most complex technical areas of mechanical engineering. The technology of pressure equipment continues to expand rapidly and recent developments in The European Pressure Equipment Directive, UK Pressure Systems Safety Regulations, and technical codes and standards are resulting in exciting changes within the industry. Key features of the volume include: concise, essential information about pressure equipment; compact and easily accessible format; fully illustrated; and core technical and legislative data.
"An Engineer's Guide to Pressure Equipment" fulfils a key role in presenting up-to-date information on pressure equipment in a practical and easy to use format. It should be a valuable source of reference for pressure equipment designers, manufacturers and end-users.
