Page 1 of 31 1 2 3 11 ... LastLast
Results 1 to 12 of 368
Thread: API Code Collections
    API Collections
    This Code contains rules for piping typically found in petroleum refineries; chemical, pharmaceutical, textile, paper, semiconductor, and cryogenic plants; and related processing plants and terminals. This Code prescribes requirements for materials and components, design, fabrication, assembly, erection, examination, inspection, and testing of piping. This Code applies to piping for all fluids including: (1) raw, intermediate, and finished chemicals; (2) petroleum products; (3) gas, steam, air and water; (4) fluidized solids; (5) refrigerants; and (6) cryogenic fluids. Also included is piping which interconnects pieces or stages within a packaged equipment assembly
    Api Standard 674 Positive Displacement Pump Reciprocating
    (1112 KB)
    API Standard 674
    (2135 KB)
    Api Standard 610 1995 Centrifugal Pumps For Petroleum Heavy Duty Chemical And Gas Industry Serv
    (11106 KB)
    API Standard 675 1994 Positive displacement pumps Controlled volume 2ed
    (2135 KB)
    API MPMS 8.2 Manual of Petro Measure Standards (Chapter 8) Sampling
    The development of consensus standards is one of API’s oldest and most successful programs. Beginning with its first standards in 1924, API now maintains some 500 standards covering all segments of the oil and gas industry. Today, the API standards program has gone global, through active involvement with the ISO and other international bodies. API is an American Petroleum Institute (ANSI) accredited standards developing organization, operating with approved standards development procedures and undergoing regular audits of its processes. API produces standards, recommended practices, specifications, codes and technical publications, reports and studies that cover each segment of the industry. API standards promote the use of safe, interchangeable equipment and operations through the use of proven, sound engineering practices as well as help reduce regulatory compliance costs, and in conjunction with API’s Quality Programs, many of these standards form the basis of API certification programs.
    (2027 KB)
    API RP 556 Instrumentation and Control Systems for Fired Heaters and Steam Generators
    American Petroleum Institute .. Publication Date:May 1, 1997
    Scope:
    This document covers recommended practices that specifically apply to instrument and control system installations for fired heaters and steam generation facilities in petroleum refinery and other hydrocarbon-processing plants. This document also discusses the installation of primary measuring instruments, control systems, alarm and shutdown systems, and automatic start-up and shutdown systems for fired heaters, steam generators, carbon monoxide or waste-gas steam generators, gas turbine exhaust-fired steam generators, and unfired waste heat steam generators. Although the information has been prepared primarily for petroleum refineries, much of it is applicable without change in chemical plants, gasoline plants, and similar installations.
    (2481 KB)
    API Standard 526- Flanged Steel Safety Relief Valves
    This Standard covers the specifications for flanged steel safety relief valves
    (1650 KB)
    API Standard 1104- Welding of Pipelines and Related Facilities
    This standard covers the gas and arc weliding of butt, fillet and socket welds in carbon, low-alloy steel piping used in the compression, pumping and transmission of crude petroleum, petroleum products, fuel gases,carbon di-oxide, nitrogen and , where applicable covers welding on distribution systems
    (1309 KB)
    API STANDARD 653, (1999) Tank Inspection Repair Alteration and Reconstruction, 2nd
    (14242 KB)
    API STANDARD 653, (2001) Tank Inspection Repair Alteration and Reconstruction, 3rd
    (5684 KB)
    API STD 614 Lubrication, Shaft-Sealing, and Control-Oil Systems and Auxiliaries for Petroleum Chemical and Gas Industry Services
    (1115 KB)
    API Std 1104
    Welding of Pipelines and Related Facilities - 20th Edition (Includes 2007 Errata)
    Edition: 20th
    American Petroleum Institute / 07-Nov-2005 / 82 pages
    API Std 620
    Design and Construction of Large, Welded, Low-Pressure Storage Tanks, Eleventh Edition
    Edition: 11th
    American Petroleum Institute / 01-Feb-2008 / 254 pages
    API Standard 653, "Tank Inspection, Repair, Alteration, and Reconstruction," was first published by the American Petroleum Institute (API) in January 1991. Its scope encompasses the maintenance, inspection, repair, alteration, and reconstruction of existing above ground, atmospheric storage tanks constructed to API 650, or its predecessor, API 12C. Since publication, tank owners, operators, and inspection companies have struggled to interpret and meet its requirements. In December 1995 API published the first major revision to API 653 in almost five years. Does this revision rewrite the rules for inspecting above ground storage tanks? This paper describes the significant changes made to API 653 and how they may influence tank inspections.
    API-specification of line pipe
    • The API 2000™ LC/MS/MS System brings the power and performance of triple quadrupole mass spectrometry to your benchtop.
    [link Point to another website Only the registered members can access] API 510 Program Information
    On this page you will find everything you need to know about obtaining API 510 certification. You also will be able to download the application package, Body of Knowledge, publications effectivity sheet and other valuable information. Please click on the appropriate headers for the information you require. If, however, after browsing this site you still have questions, please do not hesitate to contact our friendly customer service staff!
    API599
    I need UL 58, can anyone help me?
  5. Please Correct The Link of API620
    Aug 2008
    Bogota - Colombia
    The website 4shared does not work. Thanks for the other links
    Api 421
    Pls, I need API 421.
  9. [link Point to another website Only the registered members can access]
  10. API 421
    Api 421
    Pls
    Can you add to another Links instead of rapidshare.
    Api 421
    Thanks my dear, we get it .
    We apprciated your efforts
  13. I need API 672
  14. #11
    May you upload API MPMS Chapter 8 (complete) for me please ! Thanks a lot !
  16. Thankkkkkkkkkkkkkkkkkkkkkks
  1. MY Audel Books Collections
    By Han Ah kwang in forum General Engineering
    Last Post: 01-16-2014, 12:18 PM
  2. Collections of oil and gas Books
    By ameer in forum Mechanical Engineering
    Last Post: 12-05-2013, 03:52 AM
  3. AWS great collections [ask]
    By menarizki in forum Mechanical Engineering
    Last Post: 05-22-2013, 10:09 PM
  4. Replies: 4
    Last Post: 06-12-2012, 06:35 AM
  5. standards collections
    Last Post: 04-03-2010, 07:08 PM
