Page 1 of 2 1 2 LastLast
Results 1 to 12 of 22
Thread: EN 54 Standards, Latest
    Anyone out there have the latest set of EN 54 Standards? I realize Part 6 has been withdrawn, and Parts 8 and 9 I don't believe are active, but I'd still love a copy.
    I'm looking for:
    1. EN 54 part 1 Fire detection and fire alarm systems. Introduction
    2. EN 54 part 2 Fire detection and fire alarm systems. Control and indicating equipment
    3. EN 54 part 3 Fire detection and fire alarm systems. Fire alarm devices. Sounders
    4. EN 54 part 4 Fire detection and fire alarm systems. Power supply equipment
    5. EN 54 part 5 Fire detection and fire alarm systems. Heat detectors. Point detectors
    6. EN 54 part 6 Fire detection and fire alarm systems heat detectors; Rate-of-Rise point detectors without a static element
    7. EN 54 part 7 Fire detection and fire alarm systems. Smoke detector. Point detectors using scattered light, transmitted light or ionization
    8. EN 54 part 8 Components of automatic fire detection systems. Specification for high temperature heat detectors
    9. EN 54 part 9 Components of automatic fire detection systems. Methods of test of sensitivity to fire
    10. EN 54 part 10 Fire detection and fire alarm systems. Flame detector. Point detectors
    11. EN 54 part 11 Fire detection and fire alarm systems. Manual call point
    12. EN 54 part 12 Fire detection and fire alarm systems. Smoke detectors. Line detectors using an optical light beam
    13. EN 54 part 13 Fire detection and fire alarm systems. Compatibility assessment of system components
    14. EN 54 part 14 Fire detection and fire alarm systems. Cabling and interconnection of a fire detection and alarm system.
    15. EN 54 part 15 Fire detection and fire alarm systems. Point detectors using a combination of detected fire phenomena
    16. EN 54 part 16 Fire detection and fire alarm systems. Components for fire alarm voice alarm systems. Voice alarm control and indicating equipment
    17. EN 54 part 17 Fire detection and fire alarm systems. Short circuit isolators
    18. EN 54 part 18 Fire detection and fire alarm systems. Input/output devices
    19. EN 54 part 20 Fire detection and fire alarm systems. Aspirating smoke detector
    20. EN 54 part 21 Fire detection and fire alarm systems. Alarm transmission and fault warning routing equipment
    21. EN 54 part 22 Fire detection and fire alarm systems. Line type heat detectors
    22. EN 54 part 23 Fire detection and fire alarm systems. Fire alarm devices. Visual alarms
    23. EN 54 part 24 Fire detection and fire alarm systems . Voice alarms - Loudspeakers
    24. EN 54 part 25 Fire detection and fire alarm systems. Components using radio links and system requirements
    25. EN 54 part 26 Fire detection and fire alarm systems. Point fire detectors using Carbon Monoxide sensors
    26. EN 54 part 27 Fire detection and fire alarm systems. Duct smoke detectors
    27. EN 54 part 28 Non-resettable (digital) line-type heat detectors
    28. EN 54 part 30 Multi-sensor fire detectors - Point detectors using a combination of carbon monoxide and heat sensors
    D
    These are the ones that I have...
    BS EN 54 Fire detection and fire alarm systems — 2,4,7,10,11,12,13,20,25.zip
    Nabilia,
    Thanks for the standards. Now I'm only looking for:
    1. EN 54 part 6 Fire detection and fire alarm systems heat detectors; Rate-of-Rise point detectors without a static element
    2. EN 54 part 8 Components of automatic fire detection systems. Specification for high temperature heat detectors
    3. EN 54 part 9 Components of automatic fire detection systems. Methods of test of sensitivity to fire
    9. EN 54 part 21 Fire detection and fire alarm systems. Alarm transmission and fault warning routing equipment
    10. EN 54 part 22 Fire detection and fire alarm systems. Line type heat detectors
    11. EN 54 part 23 Fire detection and fire alarm systems. Fire alarm devices. Visual alarms
    12. EN 54 part 24 Fire detection and fire alarm systems . Voice alarms - Loudspeakers
    13. EN 54 part 26 Fire detection and fire alarm systems. Point fire detectors using Carbon Monoxide sensors
    14. EN 54 part 27 Fire detection and fire alarm systems. Duct smoke detectors
    15. EN 54 part 28 Non-resettable (digital) line-type heat detectors
    16. EN 54 part 30 Multi-sensor fire detectors - Point detectors using a combination of carbon monoxide and heat sensors
    Sure appreciate anyone being able to upload them.
    D
    Thank Nabilia !
    Dear Nabilia,
  9. dear all
    i going to this link but i think its not work please any help
    New link 4share is deleting all my files
  11. Thank you very much
    Please can you told me where I can find 5, 6, 8
    If there is any website please told me
    Thanks for share..
  13. Re: EN 54 Standards, Latest
    Could you please re-post the EN 54 norms. Thanks in advance.
  14. Re: EN 54 Standards, Latest
    Please re-post the EN 54 norms.
    Thanks !
    Best regards
  16. Re: EN 54 Standards, Latest
    I continue needing the standards, if someone have also EN54-30 i would like too.
  1. Latest ASME Standards
    By ramshangar in forum General Engineering
    Last Post: 04-24-2026, 01:11 PM
  2. ASTM standards latest edition only pls
    By ehtisham in forum Pipeline And Fluid Flow
    Last Post: 09-15-2014, 07:26 PM
  3. ISA Standards (Latest edition is required)
    By Sajid Ali Khan in forum Instrumentation & Control
    Last Post: 12-07-2013, 05:21 PM
  4. ASME Y14 latest Standards
    By ramakrishnadmea in forum Mechanical Engineering
    Last Post: 10-01-2013, 09:11 AM
  5. Latest PIP Standards
    By tony_black in forum General Engineering
    Last Post: 06-07-2013, 07:47 AM
