Page 1 of 3 1 2 3 LastLast
Results 1 to 12 of 29
Thread: Stahlschluessel 2004 (key to steel 2004) CD-ROM share,I need 2007 or 2010
    Smile Stahlschluessel 2004 (key to steel 2004) CD-ROM share,I need 2007 or 2010
    DL Links1:
    DL Links2:
    I Need Edition 2010 or 2007 ,Anyone have?
    The electronic Key to Steel - Stahlschlüssel on CD-ROM offers you complete new possibilities
    Decode / decipher steel desigations and find equivalent materials worldwide
    Direct access to standard numbers, symbols and designations (also with jokers)
    Search of materials by chemical composition or mechanical / physical properties with optimized algorithm
    Listing of all materials within a standard
    Direct comparison of international designation
    All German suppliers of a defined material (rough classification to shape of delivery)
    Printed report of the selected record
    Standard letter function for suppliers addresses
    Export/Import-function of material numbers, symbols and compositions for individual materials
    Choice of language (German, English, French or a user-defined language)
    Online-Helps, self-explaining screens
    Categories contained
    Structural and constructional steels
    General structural steel, case hardening steel, nitriding steel, free cutting-steel, heat-treatable steel, ball and roller bearing steel, spring steel, steel for superficial hardening, steel for cold extrusion, tough at subzero steel, pressure vessel steel, heat resisting structural steel, fine grained structural steel
    Tool steels
    Carbon tool steel, high speed steel, hot work tool steel, cold work tool steel
    Valve steels
    High temperature steels and alloys
    Nonmagnetizable steels
    Heat-resisting steels
    Heat conducting alloys
    Stainless steels
    Stainless steel castings
    Welding filler materials
    Detailed compositions and cross referenced standards and designations
    ACI · AFNOR NF · AISI · AMS · AS/NZS · ASME · ASTM · AWS · BDS · BS · CSA · CŠN · EN · EURONORM · FEDERAL · GB · GOST · IS · ISC · ISO · JB · JIS · JUS · KS · MIL · MSZ · NS · &#214;NORM · PN · SAE · SS · STAS/SR · STN · UNE · UNI · UNS · YB
    Standards and designations from 25 countries
    Australia · Austria · Brasil · Bulgaria · Canada · China · Czech/Slovac Republic · Finland · France · Germany · Great Britain · Hungary · India · Italy · Japan · Korea · Norway · Poland · Rumania · Russia · Serbia · Spain · Sweden · USA
    Indispensable for
    the mechanical engineer
    the designer
    the technical merchant
    the storeman
    the standards department
    the production
    the export department
    the heat-treating department
    the purchaser
    the materials testing department
    everyone dealing with steel
    I need or ,pls share it !!!
    Oct 2008
    The Netherlands
    Blog Entries
    14
    Thanks ddkkkI am already happy to find these old versions !!!
    Could you tell me how to install it ?
    Quote Originally Posted by FATHI View Post
    You need a Virtual CD software ('Daemon Tools' etc. ) .
    Run X:\setup.exe
    License number: 15791-PNA-FEK-TAP
    Disable CD CHECK
    Edited the "stahl2004.ini" in Programm file dir.
    ================ stahl2004.ini ===============
    [Global]
    License=FEKPNATAP15791
    UserKey=790401
    CompanyKey=654518
  7. hi ddkkk....news on 2010 editions???? i'm interested too
    Dear Friends,
    Links Are Dead...can you please re-upload in another website, like Megaupload - Ifile - Uploading etc etc
    Thank you for you kindly attention.
    Regard
    I also need 2010 version
    Thank youuuuu
    Still no one with the newer version?
  13. hxttxps://rapidshare.com/files/794917625/tryr42762.rar
    version 2010 need protection remouve
  14. #11
    Thank you
  16. #12
    the link id dead!
    pls reupload.
  1. AWWA M11 2004 Edition (Steel Pipe_ A Guide for Design & Installation.)
    By jandonian in forum Pipeline And Fluid Flow
    Last Post: 10-09-2016, 03:16 PM
  2. Replies: 3
    Last Post: 05-05-2013, 05:35 PM
  3. Key to Steel 2007 - Stahlschluessel,
    By Browndog in forum Materials Science &Corrosion
    Last Post: 10-25-2010, 02:48 PM
