Hi freinds,
I am working on Pressure vessel column and I have encountered following problem, I mean when I run the program in PV elite following MDMT requirement come i.e. Impact test is not required.
Required Minimum Design Metal Temperature 10 C
Warmest Computed Minimum Design Metal Temperature -26 C
but when i run the program after fixing all the nozzles and i found following MDMT requirement i.e.
Warmest Computed Minimum Design Metal Temperature 9 C
It means now impact test is required. so please let me know whether impact test is required for entire plate material or only nozzle material is required?
Please advise me asap.
thanking you in anticipation,
Sam
