Page 1 of 2 1 2 LastLast
Results 1 to 12 of 14
Thread: Petrel Error help
    Petrel Error help
    Hey,
    I wanted to ask you guys a quick question.
    I made a reservoir in eclipse and imported it to Petrel as I was having trouble giving the values for the dry gas.
    Now everthing is done but when i am simulating the reservoir I get an error like
    "EQUILBRATION DATA ERROR FOR REGION 1 THE DATUM DEPTH MUST BE GREATER THAN OR EQUAL TO ZERO"
    Now after beating my head on it for overn 6 hours now I have deciceded to turn to you for help and advice.
    Where exactly should I be looking to rectify the error.
    If you need more data to analysis I will be more than happy to give it to you
    Nov 2008
    Australia
    Check your SOLUTION section in the Eclipse deck.
    Sounds like you have defined the datum depth to be a negative number. Note, Petrel convention is that depth goes increasingly negative going down, while Eclipse is the opposite. So (for example) a GWC at 3000ft TVD SS would be defined as 3000 in Eclipse, while Petrel would consider it -3000
    Woo hoo man...Got it.
    Now my error has moved to
    -WARNING AT TIME 0.0 DAYS ( 1-JAN-1980):
    GAS IS DENSER THAN WATER WITHIN THE RESERVOIR
    IN EQUILIBRATION REGION 1. CHECK SURFACE
    DENSITIES, FORMATION VOLUME FACTORS, RS, RV.
    THE PROBLEM OCCURS AT DEPTH 4979.2517
    GAS PRESSURE = 3007.
    WATER PRESSURE = 3008.
    I am seeing eclipse codes everwhere now....
    Nov 2008
    Australia
    You've incorrectly defined your water and/or gas properties
    Post your entire PROPS section and I'll have a look
    The forum was down for quite some time it seems. So here
    -- THIS IS A GAS-WATER QUARTER FIVE SPOT.
    RUNSPEC
    TITLE
    GAS-WATER TEST CASE
    DIMENS
    20 20 4 /
    WATER
    GAS
    FIELD
    SATOPTS
    'HYSTER' /
    TABDIMS
    2 1 20 20 1 20 /
    WELLDIMS
    2 1 1 2 /
    START
    1 'JAN' 1983 /
    GRID ================================================== ============
    TOPS
    --Inclined reservoir at 25 degrees slope -1.037
    20*3000
    20*2998.8963
    20*2997.7926
    20*2996.6889
    20*2995.5852
    20*2994.4815
    20*2993.3778
    20*2992.2741
    20*2991.1704
    20*2990.0667
    20*2988.963
    20*2987.8593
    20*2986.7556
    20*2985.6519
    20*2984.5482
    20*2983.4445
    20*2982.3408
    20*2981.2371
    20*2980.1334
    20*2979.0297
    20*2977.926
    20*2976.8223
    20*2975.7186
    20*2974.6149
    20*2973.5112
    20*2972.4075
    20*2971.3038
    20*2970.2001
    20*2969.0964
    20*2967.9927
    20*2966.889
    20*2965.7853
    20*2964.6816
    20*2963.5779
    20*2962.4742
    20*2961.3705
    20*2960.2668
    20*2959.1631
    20*2958.0594
    20*2956.9557
    20*2955.852
    20*2954.7483
    20*2953.6446
    20*2952.5409
    20*2951.4372
    20*2920.3335
    20*2949.2298
    20*2948.1261
    20*2947.0224
    20*2945.9187
    20*2944.815
    DXV
    20*75.0 /
    DYV
    20*75.0 /
    DZ
    1600*30.0 /
    TOPS
    400*4000.0 /
    PORO
    1600*0.2 /
    PERMX
    1600*50.0 /
    PERMY
    1600*50.0 /
    PERMZ
    1600*50.0 /
    PROPS ================================================== ============
    RVCONST
    0.01 /
    SWFN
    .25 .0 0.0
    .7 1.0 0.0
    .25 .0 0.0
    .5 1.0 0.0
    SGFN
    .3 .0 0.0
    .75 1.0 0.0
    .5 .0 0.0
    .75 1.0 0.0
    PVTW
    .0 1.0 3.03E-06 .5 0.0 /
    PVDG
    .0 1.0 2.0
    8000.0 .92 2.0
    ROCK
    4000.0 .30E-05 /
    DENSITY
    52.0000 64.0000 .04400 /
    RPTPROPS
    2*0 /
    REGIONS ================================================== ===========
    SATNUM
    1600*1 /
    IMBNUM
    1600*1 /
    SOLUTION ================================================== ===========
    DEBUG
    2 4 /
    SWAT
    1600*0.7 /
    PRVD
    4000 4000
    4300 4150 /
    RPTSOL
    1 0 1 0 0 0 2 /
    SCHEDULE ================================================== =========
    RPTSCHED
    1 0 1 0 0 0 2 /
    WELSPECS
    'P1' 'G' 1 1 4000 'GAS' /
    'P2' 'G' 20 20 4000 'GAS' /
    WELDEBUG
    'P1' 2211 /
    'P2' 2211 /
    COMPDAT
    'P1 ' 1 1 1 1 'OPEN' 0 .0 1.0 /
    'P2 ' 20 20 1 1 'OPEN' 0 .0 1.0 /
    WCONPROD
    'P1' 'OPEN' 'BHP' 5* 4000.0 /
    'P2' 'OPEN' 'BHP' 5* 4000.0 /
    TSTEP
    10
    TSTEP
    2990
    END
    I have made a few changes in the mean while and the original error is gone. It is replaced with a new one.
    Nov 2008
    Australia
    Remove the trailing characters after the GRID / PROPS statements - there must tabs or something in there that Eclipse doesn't like
    You've defined a 20x20x4 model (1,600 cells), and need to define tops for at minimum 400 cells (top layer) or all of them, but you've defined 1,020 of them (and then defined again 400 of them)....
    The top of your cell 1,1,1 as defined is actually your deepest cell - meaning your model is upside down. Have remade it with a 3,000ft depth at 1,1,1 and a 2.5 deg dip in the J direction (I assume you didn't mean 25 deg)
    Did you actually want to use Hysteresis option? - Have turned off
    Not sure where your properties for gas & water come from, but it's not good practice to define a pressure point at 0 psi. Have changed to 14.7
    You've define gas rel perm to be zero at gas saturations 30% or less, and then given all cells 70% water saturation - the model doesn't flow. Have removed refernce to initial water saturation so it will default to 30% from the rel perm tables
    You've defined well reference depths at 4,00ft, yet the structure is not that deep - changed to 3,000ft
    Have you meant to only connect/perforate the top layer? Have left alone, but you may want to check
    Your pressure vs depth is defined from 4,000ft down, and explicitly defined pressures - yuck...
    Have changed to equilibrium definition at 3,000ft and put in a more realistic pressure - Have assumed you want pure gas (no contact)
    Have put in more realistic well FBHP limit (300 psi drawdown) - you had defined 4,000psi FBHP
    The model now runs, but not for long due to lack of pressure support
    Good luck
    RUNSPEC
    TITLE
    GAS-WATER TEST CASE
    DIMENS
    20 20 4 /
    WATER
    GAS
    FIELD
    -- SATOPTS
    -- 'HYSTER' /
    TABDIMS
    2 1 20 20 1 20 /
    WELLDIMS
    2 1 1 2 /
    START
    1 'JAN' 1983 /
    GRID
    TOPS
    --Inclined reservoir at 2.5 degrees
    20*3000
    20*3003.274571
    20*3006.549141
    20*3009.823712
    20*3013.098283
    20*3016.372854
    20*3019.647424
    20*3022.921995
    20*3026.196566
    20*3029.471136
    20*3032.745707
    20*3036.020278
    20*3039.294849
    20*3042.569419
    20*3045.84399
    20*3049.118561
    20*3052.393131
    20*3055.667702
    20*3058.942273
    20*3062.216844
    DXV
    20*75.0 /
    DYV
    20*75.0 /
    DZ
    1600*30.0 /
    PORO
    1600*0.2 /
    PERMX
    1600*50.0 /
    PERMY
    1600*50.0 /
    PERMZ
    1600*50.0 /
    PROPS
    RVCONST
    0.01 /
    SWFN
    .25 .0 0.0
    .7 1.0 0.0
    .25 .0 0.0
    .5 1.0 0.0
    SGFN
    .3 .0 0.0
    .75 1.0 0.0
    .5 .0 0.0
    .75 1.0 0.0
    PVTW
    14.7 1.0 3.03E-06 .5 0.0 /
    PVDG
    14.7 1.0 2.0
    8000.0 .92 2.0
    ROCK
    4000.0 .30E-05 /
    DENSITY
    RPTPROPS
    2*0 /
    SATNUM
    1600*1 /
    --IMBNUM
    --1600*1 /
    DEBUG
    2 4 /
    --PRVD
    --4000 4000
    --4300 4150 /
    EQUIL
    3000 1300 4000 0 4000 /
    RPTSOL
    1 0 1 0 0 0 2 /
    RPTSCHED
    1 0 1 0 0 0 2 /
    WELSPECS
    'P1' 'G' 1 1 3000 'GAS' /
    'P2' 'G' 20 20 3000 'GAS' /
    WELDEBUG
    'P1' 2211 /
    'P2' 2211 /
    COMPDAT
    WCONPROD
    'P1' 'OPEN' 'BHP' 5* 1000.0 /
    'P2' 'OPEN' 'BHP' 5* 1000.0 /
    TSTEP
    10
    TSTEP
    2990
    END
    Dear Tejaswy,
    Why not you prepare such a simple model in Petrel. It is very easy to prepare model in Petrel.
    Nov 2008
    Australia
    Indeed you can prepare this sort of model with the assistance of Petrel RE, but I would strongly advocate to do this sort of work manually - for the beginner it is a good chance to improve your understanding, and for the more experienced simulation engineer it is far more efficient to do it manually - I could create that deck in about 10-mins by hand....
    I normally use Petrel for tasks such as upscaling, creating calculated properties (OPERNUM regions etc), defining faults, creating initial COMPDAT's etc... in short the raw inputs for simulation - but then prefer to do the actual simulation work manually.... and no I'm not a crusty old fart who sticks their nose up at anything without punch cards ;-)..... I really started with a very positive and optimistic opinion of how Petrel RE could assist the simulation workflow, but have lowered my expectations somewhat after some years of working with it. Don't get me wrong, it's a useful tool to know how to use, and I do use it frequently - I just use TextPad far more.
    Thanks vinomarky for the help with the reservoir.
    The thing with Petrel is that I have an educational version of it and it is very limited in terms of putting horizontal wells and exporting it to other formats.
    With Eclispe I can put in a a horizontal well where ever i please and It is really easy to put one, given that you know how you want your well to go.
    And With Eclipse you get a feel of your reservoir and well you get a good feeling when you reservoir runs perfectly. ( Can you feeeeeeeeeeeeel it.... then lets go for it - Kaho na Pyar hai, hindi movie)
    Petrel is good in its own right but it is not so good for newbies, It is a fancy gui version of Eclipse and Flogrid.
    I do appreciate your help VinoMarky, I am just a little tied up with some university work and I will get back to you on the reservoir. I will be putting in a aquifger to support the production for longer.
    Hi vinoMarky
    I am back again to seek your help, AGAIN, After copying pasting stuff from the eclipse example file and a lot of rectifying, I have made the following reservoir .
    Now even after adding the aquifer I fail to see any significant change in the production profile.
    What do you think of it?
    As in the whole point of doing this is so that i produce some water from well 2 and then shut it.
    RUNSPEC
    TITLE
    GAS-WATER TEST CASE
    DIMENS
    20 20 4 /
    WATER
    GAS
    FIELD
    -- SATOPTS
    -- 'HYSTER' /
    TABDIMS
    2 1 20 20 1 20 /
    WELLDIMS
    2 1 1 2 /
    AQUDIMS
    240 1 0 0 0 0 /
    START
    1 'JAN' 2010 /
    GRID
    TOPS
    20*3000
    20*3003.274571
    20*3006.549141
    20*3009.823712
    20*3013.098283
    20*3016.372854
    20*3019.647424
    20*3022.921995
    20*3026.196566
    20*3029.471136
    20*3032.745707
    20*3036.020278
    20*3039.294849
    20*3042.569419
    20*3045.84399
    20*3049.118561
    20*3052.393131
    20*3055.667702
    20*3058.942273
    20*3062.216844
    DXV
    20*75.0 /
    DYV
    20*75.0 /
    DZ
    1600*30.0 /
    PORO
    1600*0.2 /
    PERMX
    1600*50.0 /
    PERMY
    1600*50.0 /
    PERMZ
    1600*50.0 /
    AQUNUM
    1 20 18 1 1.0E+5 20000 1* 200.0 2* 1 1/
    1 19 18 1 1.0E+5 20000 1* 200.0 2* 1 1/
    1 18 18 1 1.0E+5 20000 1* 200.0 2* 1 1/
    1 17 18 1 1.0E+5 20000 1* 200.0 2* 1 1/
    1 16 18 1 1.0E+5 20000 1* 200.0 2* 1 1/
    1 15 18 1 1.0E+5 20000 1* 200.0 2* 1 1/
    1 14 18 1 1.0E+5 20000 1* 200.0 2* 1 1/
    1 13 18 1 1.0E+5 20000 1* 200.0 2* 1 1/
    1 12 18 1 1.0E+5 20000 1* 200.0 2* 1 1/
    1 11 18 1 1.0E+5 20000 1* 200.0 2* 1 1/
    1 10 18 1 1.0E+5 20000 1* 200.0 2* 1 1/
    1 9 18 1 1.0E+5 20000 1* 200.0 2* 1 1/
    1 8 18 1 1.0E+5 20000 1* 200.0 2* 1 1/
    1 7 18 1 1.0E+5 20000 1* 200.0 2* 1 1/
    1 6 18 1 1.0E+5 20000 1* 200.0 2* 1 1/
    1 5 18 1 1.0E+5 20000 1* 200.0 2* 1 1/
    1 4 18 1 1.0E+5 20000 1* 200.0 2* 1 1/
    1 3 18 1 1.0E+5 20000 1* 200.0 2* 1 1/
    1 2 18 1 1.0E+5 20000 1* 200.0 2* 1 1/
    1 1 18 1 1.0E+5 20000 1* 200.0 2* 1 1/
    1 20 18 2 1.0E+5 20000 1* 200.0 2* 1 1/
    1 19 18 2 1.0E+5 20000 1* 200.0 2* 1 1/
    1 18 18 2 1.0E+5 20000 1* 200.0 2* 1 1/
    1 17 18 2 1.0E+5 20000 1* 200.0 2* 1 1/
    1 16 18 2 1.0E+5 20000 1* 200.0 2* 1 1/
    1 15 18 2 1.0E+5 20000 1* 200.0 2* 1 1/
    1 14 18 2 1.0E+5 20000 1* 200.0 2* 1 1/
    1 13 18 2 1.0E+5 20000 1* 200.0 2* 1 1/
    1 12 18 2 1.0E+5 20000 1* 200.0 2* 1 1/
    1 11 18 2 1.0E+5 20000 1* 200.0 2* 1 1/
    1 10 18 2 1.0E+5 20000 1* 200.0 2* 1 1/
    1 9 18 2 1.0E+5 20000 1* 200.0 2* 1 1/
    1 8 18 2 1.0E+5 20000 1* 200.0 2* 1 1/
    1 7 18 2 1.0E+5 20000 1* 200.0 2* 1 1/
    1 6 18 2 1.0E+5 20000 1* 200.0 2* 1 1/
    1 5 18 2 1.0E+5 20000 1* 200.0 2* 1 1/
    1 4 18 2 1.0E+5 20000 1* 200.0 2* 1 1/
    1 3 18 2 1.0E+5 20000 1* 200.0 2* 1 1/
    1 2 18 2 1.0E+5 20000 1* 200.0 2* 1 1/
    1 1 18 2 1.0E+5 20000 1* 200.0 2* 1 1/
    1 20 18 3 1.0E+5 20000 1* 200.0 2* 1 1/
    1 19 18 3 1.0E+5 20000 1* 200.0 2* 1 1/
    1 18 18 3 1.0E+5 20000 1* 200.0 2* 1 1/
    1 17 18 3 1.0E+5 20000 1* 200.0 2* 1 1/
    1 16 18 3 1.0E+5 20000 1* 200.0 2* 1 1/
    1 15 18 3 1.0E+5 20000 1* 200.0 2* 1 1/
    1 14 18 3 1.0E+5 20000 1* 200.0 2* 1 1/
    1 13 18 3 1.0E+5 20000 1* 200.0 2* 1 1/
    1 12 18 3 1.0E+5 20000 1* 200.0 2* 1 1/
    1 11 18 3 1.0E+5 20000 1* 200.0 2* 1 1/
    1 10 18 3 1.0E+5 20000 1* 200.0 2* 1 1/
    1 9 18 3 1.0E+5 20000 1* 200.0 2* 1 1/
    1 8 18 3 1.0E+5 20000 1* 200.0 2* 1 1/
    1 7 18 3 1.0E+5 20000 1* 200.0 2* 1 1/
    1 6 18 3 1.0E+5 20000 1* 200.0 2* 1 1/
    1 5 18 3 1.0E+5 20000 1* 200.0 2* 1 1/
    1 4 18 3 1.0E+5 20000 1* 200.0 2* 1 1/
    1 3 18 3 1.0E+5 20000 1* 200.0 2* 1 1/
    1 2 18 3 1.0E+5 20000 1* 200.0 2* 1 1/
    1 1 18 3 1.0E+5 20000 1* 200.0 2* 1 1/
    1 20 18 4 1.0E+5 20000 1* 200.0 2* 1 1/
    1 19 18 4 1.0E+5 20000 1* 200.0 2* 1 1/
    1 18 18 4 1.0E+5 20000 1* 200.0 2* 1 1/
    1 17 18 4 1.0E+5 20000 1* 200.0 2* 1 1/
    1 16 18 4 1.0E+5 20000 1* 200.0 2* 1 1/
    1 15 18 4 1.0E+5 20000 1* 200.0 2* 1 1/
    1 14 18 4 1.0E+5 20000 1* 200.0 2* 1 1/
    1 13 18 4 1.0E+5 20000 1* 200.0 2* 1 1/
    1 12 18 4 1.0E+5 20000 1* 200.0 2* 1 1/
    1 11 18 4 1.0E+5 20000 1* 200.0 2* 1 1/
    1 10 18 4 1.0E+5 20000 1* 200.0 2* 1 1/
    1 9 18 4 1.0E+5 20000 1* 200.0 2* 1 1/
    1 8 18 4 1.0E+5 20000 1* 200.0 2* 1 1/
    1 7 18 4 1.0E+5 20000 1* 200.0 2* 1 1/
    1 6 18 4 1.0E+5 20000 1* 200.0 2* 1 1/
    1 5 18 4 1.0E+5 20000 1* 200.0 2* 1 1/
    1 4 18 4 1.0E+5 20000 1* 200.0 2* 1 1/
    1 3 18 4 1.0E+5 20000 1* 200.0 2* 1 1/
    1 2 18 4 1.0E+5 20000 1* 200.0 2* 1 1/
    1 1 18 4 1.0E+5 20000 1* 200.0 2* 1 1/
    1 20 19 1 1.0E+5 20000 1* 200.0 2* 1 1/
    1 19 19 1 1.0E+5 20000 1* 200.0 2* 1 1/
    1 18 19 1 1.0E+5 20000 1* 200.0 2* 1 1/
    1 17 19 1 1.0E+5 20000 1* 200.0 2* 1 1/
    1 16 19 1 1.0E+5 20000 1* 200.0 2* 1 1/
    1 15 19 1 1.0E+5 20000 1* 200.0 2* 1 1/
    1 14 19 1 1.0E+5 20000 1* 200.0 2* 1 1/
    1 13 19 1 1.0E+5 20000 1* 200.0 2* 1 1/
    1 12 19 1 1.0E+5 20000 1* 200.0 2* 1 1/
    1 11 19 1 1.0E+5 20000 1* 200.0 2* 1 1/
    1 10 19 1 1.0E+5 20000 1* 200.0 2* 1 1/
    1 9 19 1 1.0E+5 20000 1* 200.0 2* 1 1/
    1 8 19 1 1.0E+5 20000 1* 200.0 2* 1 1/
    1 7 19 1 1.0E+5 20000 1* 200.0 2* 1 1/
    1 6 19 1 1.0E+5 20000 1* 200.0 2* 1 1/
    1 5 19 1 1.0E+5 20000 1* 200.0 2* 1 1/
    1 4 19 1 1.0E+5 20000 1* 200.0 2* 1 1/
    1 3 19 1 1.0E+5 20000 1* 200.0 2* 1 1/
    1 2 19 1 1.0E+5 20000 1* 200.0 2* 1 1/
    1 1 19 1 1.0E+5 20000 1* 200.0 2* 1 1/
    1 20 19 2 1.0E+5 20000 1* 200.0 2* 1 1/
    1 19 19 2 1.0E+5 20000 1* 200.0 2* 1 1/
    1 18 19 2 1.0E+5 20000 1* 200.0 2* 1 1/
    1 17 19 2 1.0E+5 20000 1* 200.0 2* 1 1/
    1 16 19 2 1.0E+5 20000 1* 200.0 2* 1 1/
    1 15 19 2 1.0E+5 20000 1* 200.0 2* 1 1/
    1 14 19 2 1.0E+5 20000 1* 200.0 2* 1 1/
    1 13 19 2 1.0E+5 20000 1* 200.0 2* 1 1/
    1 12 19 2 1.0E+5 20000 1* 200.0 2* 1 1/
    1 11 19 2 1.0E+5 20000 1* 200.0 2* 1 1/
    1 10 19 2 1.0E+5 20000 1* 200.0 2* 1 1/
    1 9 19 2 1.0E+5 20000 1* 200.0 2* 1 1/
    1 8 19 2 1.0E+5 20000 1* 200.0 2* 1 1/
    1 7 19 2 1.0E+5 20000 1* 200.0 2* 1 1/
    1 6 19 2 1.0E+5 20000 1* 200.0 2* 1 1/
    1 5 19 2 1.0E+5 20000 1* 200.0 2* 1 1/
    1 4 19 2 1.0E+5 20000 1* 200.0 2* 1 1/
    1 3 19 2 1.0E+5 20000 1* 200.0 2* 1 1/
    1 2 19 2 1.0E+5 20000 1* 200.0 2* 1 1/
    1 1 19 2 1.0E+5 20000 1* 200.0 2* 1 1/
    1 20 19 3 1.0E+5 20000 1* 200.0 2* 1 1/
    1 19 19 3 1.0E+5 20000 1* 200.0 2* 1 1/
    1 18 19 3 1.0E+5 20000 1* 200.0 2* 1 1/
    1 17 19 3 1.0E+5 20000 1* 200.0 2* 1 1/
    1 16 19 3 1.0E+5 20000 1* 200.0 2* 1 1/
    1 15 19 3 1.0E+5 20000 1* 200.0 2* 1 1/
    1 14 19 3 1.0E+5 20000 1* 200.0 2* 1 1/
    1 13 19 3 1.0E+5 20000 1* 200.0 2* 1 1/
    1 12 19 3 1.0E+5 20000 1* 200.0 2* 1 1/
    1 11 19 3 1.0E+5 20000 1* 200.0 2* 1 1/
    1 10 19 3 1.0E+5 20000 1* 200.0 2* 1 1/
    1 9 19 3 1.0E+5 20000 1* 200.0 2* 1 1/
    1 8 19 3 1.0E+5 20000 1* 200.0 2* 1 1/
    1 7 19 3 1.0E+5 20000 1* 200.0 2* 1 1/
    1 6 19 3 1.0E+5 20000 1* 200.0 2* 1 1/
    1 5 19 3 1.0E+5 20000 1* 200.0 2* 1 1/
    1 4 19 3 1.0E+5 20000 1* 200.0 2* 1 1/
    1 3 19 3 1.0E+5 20000 1* 200.0 2* 1 1/
    1 2 19 3 1.0E+5 20000 1* 200.0 2* 1 1/
    1 1 19 3 1.0E+5 20000 1* 200.0 2* 1 1/
    1 20 19 4 1.0E+5 20000 1* 200.0 2* 1 1/
    1 19 19 4 1.0E+5 20000 1* 200.0 2* 1 1/
    1 18 19 4 1.0E+5 20000 1* 200.0 2* 1 1/
    1 17 19 4 1.0E+5 20000 1* 200.0 2* 1 1/
    1 16 19 4 1.0E+5 20000 1* 200.0 2* 1 1/
    1 15 19 4 1.0E+5 20000 1* 200.0 2* 1 1/
    1 14 19 4 1.0E+5 20000 1* 200.0 2* 1 1/
    1 13 19 4 1.0E+5 20000 1* 200.0 2* 1 1/
    1 12 19 4 1.0E+5 20000 1* 200.0 2* 1 1/
    1 11 19 4 1.0E+5 20000 1* 200.0 2* 1 1/
    1 10 19 4 1.0E+5 20000 1* 200.0 2* 1 1/
    1 9 19 4 1.0E+5 20000 1* 200.0 2* 1 1/
    1 8 19 4 1.0E+5 20000 1* 200.0 2* 1 1/
    1 7 19 4 1.0E+5 20000 1* 200.0 2* 1 1/
    1 6 19 4 1.0E+5 20000 1* 200.0 2* 1 1/
    1 5 19 4 1.0E+5 20000 1* 200.0 2* 1 1/
    1 4 19 4 1.0E+5 20000 1* 200.0 2* 1 1/
    1 3 19 4 1.0E+5 20000 1* 200.0 2* 1 1/
    1 2 19 4 1.0E+5 20000 1* 200.0 2* 1 1/
    1 1 19 4 1.0E+5 20000 1* 200.0 2* 1 1/
    1 20 20 1 1.0E+5 20000 1* 200.0 2* 1 1/
    1 19 20 1 1.0E+5 20000 1* 200.0 2* 1 1/
    1 18 20 1 1.0E+5 20000 1* 200.0 2* 1 1/
    1 17 20 1 1.0E+5 20000 1* 200.0 2* 1 1/
    1 16 20 1 1.0E+5 20000 1* 200.0 2* 1 1/
    1 15 20 1 1.0E+5 20000 1* 200.0 2* 1 1/
    1 14 20 1 1.0E+5 20000 1* 200.0 2* 1 1/
    1 13 20 1 1.0E+5 20000 1* 200.0 2* 1 1/
    1 12 20 1 1.0E+5 20000 1* 200.0 2* 1 1/
    1 11 20 1 1.0E+5 20000 1* 200.0 2* 1 1/
    1 10 20 1 1.0E+5 20000 1* 200.0 2* 1 1/
    1 9 20 1 1.0E+5 20000 1* 200.0 2* 1 1/
    1 8 20 1 1.0E+5 20000 1* 200.0 2* 1 1/
    1 7 20 1 1.0E+5 20000 1* 200.0 2* 1 1/
    1 6 20 1 1.0E+5 20000 1* 200.0 2* 1 1/
    1 5 20 1 1.0E+5 20000 1* 200.0 2* 1 1/
    1 4 20 1 1.0E+5 20000 1* 200.0 2* 1 1/
    1 3 20 1 1.0E+5 20000 1* 200.0 2* 1 1/
    1 2 20 1 1.0E+5 20000 1* 200.0 2* 1 1/
    1 1 20 1 1.0E+5 20000 1* 200.0 2* 1 1/
    1 20 20 2 1.0E+5 20000 1* 200.0 2* 1 1/
    1 19 20 2 1.0E+5 20000 1* 200.0 2* 1 1/
    1 18 20 2 1.0E+5 20000 1* 200.0 2* 1 1/
    1 17 20 2 1.0E+5 20000 1* 200.0 2* 1 1/
    1 16 20 2 1.0E+5 20000 1* 200.0 2* 1 1/
    1 15 20 2 1.0E+5 20000 1* 200.0 2* 1 1/
    1 14 20 2 1.0E+5 20000 1* 200.0 2* 1 1/
    1 13 20 2 1.0E+5 20000 1* 200.0 2* 1 1/
    1 12 20 2 1.0E+5 20000 1* 200.0 2* 1 1/
    1 11 20 2 1.0E+5 20000 1* 200.0 2* 1 1/
    1 10 20 2 1.0E+5 20000 1* 200.0 2* 1 1/
    1 9 20 2 1.0E+5 20000 1* 200.0 2* 1 1/
    1 8 20 2 1.0E+5 20000 1* 200.0 2* 1 1/
    1 7 20 2 1.0E+5 20000 1* 200.0 2* 1 1/
    1 6 20 2 1.0E+5 20000 1* 200.0 2* 1 1/
    1 5 20 2 1.0E+5 20000 1* 200.0 2* 1 1/
    1 4 20 2 1.0E+5 20000 1* 200.0 2* 1 1/
    1 3 20 2 1.0E+5 20000 1* 200.0 2* 1 1/
    1 2 20 2 1.0E+5 20000 1* 200.0 2* 1 1/
    1 1 20 2 1.0E+5 20000 1* 200.0 2* 1 1/
    1 20 20 3 1.0E+5 20000 1* 200.0 2* 1 1/
    1 19 20 3 1.0E+5 20000 1* 200.0 2* 1 1/
    1 18 20 3 1.0E+5 20000 1* 200.0 2* 1 1/
    1 17 20 3 1.0E+5 20000 1* 200.0 2* 1 1/
    1 16 20 3 1.0E+5 20000 1* 200.0 2* 1 1/
    1 15 20 3 1.0E+5 20000 1* 200.0 2* 1 1/
    1 14 20 3 1.0E+5 20000 1* 200.0 2* 1 1/
    1 13 20 3 1.0E+5 20000 1* 200.0 2* 1 1/
    1 12 20 3 1.0E+5 20000 1* 200.0 2* 1 1/
    1 11 20 3 1.0E+5 20000 1* 200.0 2* 1 1/
    1 10 20 3 1.0E+5 20000 1* 200.0 2* 1 1/
    1 9 20 3 1.0E+5 20000 1* 200.0 2* 1 1/
    1 8 20 3 1.0E+5 20000 1* 200.0 2* 1 1/
    1 7 20 3 1.0E+5 20000 1* 200.0 2* 1 1/
    1 6 20 3 1.0E+5 20000 1* 200.0 2* 1 1/
    1 5 20 3 1.0E+5 20000 1* 200.0 2* 1 1/
    1 4 20 3 1.0E+5 20000 1* 200.0 2* 1 1/
    1 3 20 3 1.0E+5 20000 1* 200.0 2* 1 1/
    1 2 20 3 1.0E+5 20000 1* 200.0 2* 1 1/
    1 1 20 3 1.0E+5 20000 1* 200.0 2* 1 1/
    1 20 20 4 1.0E+5 20000 1* 200.0 2* 1 1/
    1 19 20 4 1.0E+5 20000 1* 200.0 2* 1 1/
    1 18 20 4 1.0E+5 20000 1* 200.0 2* 1 1/
    1 17 20 4 1.0E+5 20000 1* 200.0 2* 1 1/
    1 16 20 4 1.0E+5 20000 1* 200.0 2* 1 1/
    1 15 20 4 1.0E+5 20000 1* 200.0 2* 1 1/
    1 14 20 4 1.0E+5 20000 1* 200.0 2* 1 1/
    1 13 20 4 1.0E+5 20000 1* 200.0 2* 1 1/
    1 12 20 4 1.0E+5 20000 1* 200.0 2* 1 1/
    1 11 20 4 1.0E+5 20000 1* 200.0 2* 1 1/
    1 10 20 4 1.0E+5 20000 1* 200.0 2* 1 1/
    1 9 20 4 1.0E+5 20000 1* 200.0 2* 1 1/
    1 8 20 4 1.0E+5 20000 1* 200.0 2* 1 1/
    1 7 20 4 1.0E+5 20000 1* 200.0 2* 1 1/
    1 6 20 4 1.0E+5 20000 1* 200.0 2* 1 1/
    1 5 20 4 1.0E+5 20000 1* 200.0 2* 1 1/
    1 4 20 4 1.0E+5 20000 1* 200.0 2* 1 1/
    1 3 20 4 1.0E+5 20000 1* 200.0 2* 1 1/
    1 2 20 4 1.0E+5 20000 1* 200.0 2* 1 1/
    1 1 20 4 1.0E+5 20000 1* 200.0 2* 1 1/
    AQUCON
    1 5 5 1 1 1 3 'I+' 1.0 /
    PROPS
    RVCONST
    0.01 /
    SWFN
    .25 .0 0.0
    .7 1.0 0.0
    .25 .0 0.0
    .5 1.0 0.0
    SGFN
    .3 .0 0.0
    .75 1.0 0.0
    .5 .0 0.0
    .75 1.0 0.0
    PVTW
    PVDG
    14.7 1.0 2.0
    8000.0 .92 2.0
    ROCK
    4000.0 .30E-05 /
    DENSITY
    RPTPROPS
    2*0 /
    SATNUM
    1600*1 /
    --IMBNUM
    --1600*1 /
    DEBUG
    2 4 /
    --PRVD
    --4000 4000
    --4300 4150 /
    EQUIL
    3000 3000 4000 0 4000 /
    RPTSOL
    1 0 1 0 0 0 2 /
    SUMMARY ================================================== =========
    --Neat tabulated output of summary file data at the end of the normal
    --Eclipse printed output
    RUNSUM
    EXCEL
    FGPR
    FWPR
    RPTSMRY
    1 /
    SEPARATE
    RPTSCHED
    1 0 1 0 0 0 2 /
    WELSPECS
    'P1' 'G' 10 1 3000 'GAS' /
    'P2' 'G' 10 14 3000 'GAS' /
    WELDEBUG
    'P1' 2211 /
    'P2' 2211 /
    COMPDAT
    'P1 ' 10 1 1 1 'OPEN' 0 .0 1.0 /
    'P2 ' 10 14 1 1 'OPEN' 0 .0 1.0 /
    WCONPROD
    TSTEP
    100
    TSTEP
    2990
    END
  14. #11
    Nov 2008
    Australia
    I believe it is related to your gas properties - with so little change in formation volume factor over the range of 14.7 to 8,000 psi, there is little expansion happening. Modify your PVDG table to be something like the below and I think you'll find a far greater recovery factor due to the increased expansion
    Note: Eclipse extrapolates gas FVF by a pressure vs 1/Bg method, so it's good to check this relationship to make sure it is smooth
    Also note that your initially defined gas viscosities were too high
    PVDG
    --4.7 1.0 2.0
    --8000.0 .92 2.0
    14.7 229.9469 0.013547
    1025 3.0760 0.014754
    2036 1.4804 0.017086
    3047 0.9924 0.020228
    8000 0.5297 0.034860
  16. #12
    HI vinomarky,
    You are right, the gas viscosities defined are too high. Actualy I took them from the eclipse data file with out giving too much thought.
    Changes done
    I changed the needful,
    1.Increased the depth of the wells from 1 to 4
    2.Added a aquifer,
    3.Removed the EQUILS to change the SW of the entire reservoir to 0.5 (the aquifer is 1) and
    4.Changed the PRVD
    and the model now somewhat runs fine.
    I would how ever appreciate your expert comments on the following simulation
    RUNSPEC
    TITLE
    GAS-WATER TEST CASE
    DIMENS
    20 20 4 /
    WATER
    GAS
    FIELD
    -- SATOPTS
    -- 'HYSTER' /
    TABDIMS
    2 1 20 20 1 20 /
    WELLDIMS
    2 4 1 2 /
    AQUDIMS
    240 1 0 0 0 0 /
    START
    1 'JAN' 2010 /
    GRID
    TOPS
    --Inclined reservoir at 2.5 degrees slope -1.037
    20*3000
    20*3003.274571
    20*3006.549141
    20*3009.823712
    20*3013.098283
    20*3016.372854
    20*3019.647424
    20*3022.921995
    20*3026.196566
    20*3029.471136
    20*3032.745707
    20*3036.020278
    20*3039.294849
    20*3042.569419
    20*3045.84399
    20*3049.118561
    20*3052.393131
    20*3055.667702
    20*3058.942273
    20*3062.216844
    DXV
    20*75.0 /
    DYV
    20*75.0 /
    DZ
    1600*30.0 /
    PORO
    1600*0.2 /
    PERMX
    1600*50.0 /
    PERMY
    1600*50.0 /
    PERMZ
    1600*50.0 /
    --THE AQUIFER CELLS ARE SET UP USING THE AQUNUM KEYWORD
    --ALL BELONG TO AQUIFER 1, AND CONNECTIONS ARE MADE TO THE FIRST
    --CELL SPECIFIED WITH A GIVEN AQUIFER NUMBER - IN THIS CASE (20,18,x)
    -- (20,19,x) and (20,20,x) x = 1,2,3,4
    AQUNUM
    AQUCON
    PROPS
    RVCONST
    0.01 /
    SWFN
    .25 .0 0.0
    .7 1.0 0.0
    .25 .0 0.0
    .5 1.0 0.0
    SGFN
    .3 .0 0.0
    .75 1.0 0.0
    .5 .0 0.0
    .75 1.0 0.0
    PVTW
    PVDG
    --4.7 1.0 2.0
    --8000.0 .92 2.0
    1025.5 3.0760 0.014754
    2036.3 1.4804 0.017086
    3047.1 0.9924 0.020228
    8000.0 0.5297 0.034860
    ROCK
    4000.0 .30E-05 /
    DENSITY
    RPTPROPS
    2*0 /
    SATNUM
    1600*1 /
    --IMBNUM
    --1600*1 /
    DEBUG
    2 4 /
    SWAT
    1600*0.5/
    PRVD
    3000 6000
    3500 6400 /
    RPTSOL
    1 0 1 0 0 0 2 /
    RUNSUM
    EXCEL
    FGPR
    FWPR
    RPTSMRY
    1 /
    SEPARATE
    RPTSCHED
    1 0 1 0 0 0 2 /
    WELSPECS
    WELDEBUG
    'P1' 2211 /
    'P2' 2211 /
    COMPDAT
    'P1 ' 10 1 1 4 'OPEN' 0 .0 1.0 /
    'P2 ' 10 14 1 4 'OPEN' 0 .0 1.0 /
    WCONPROD
    TSTEP
    100
    TSTEP
    2990
    END
  1. Replies: 35
    Last Post: 03-11-2019, 08:08 PM
  2. Exchange Petrel Seismic to Sim with Petrel RE Course
    By Albertmeine in forum Reservoir
    Last Post: 12-05-2013, 05:52 PM
