Thread: please help me with an injection well
    Apr 2009
    south america
    Please I need your help. We have a Disposal Well, for seven years was injected into the well.
    I have two question:
    1.-how to calculate the current reservoir pressure (after 7 years of injection)
    2 .- It may be that the pressure in the reservoir reaches such a high value that will produce the return of water injected into the well?
    Thanks a lot!!!
    Nov 2008
    Australia
    You can get an estimate from a falloff plot.
    Simply, stop injecting and plot WHP decline with SQRT time - extrapolate like you would a Horner plot
    If you well cannot support a full column of fluid then you either need a BHP guage, OR (if you can tolerate less accuracy) take a number of sonalogs down the annulus with time (calculating level of fluid) to infer declining pressure - gives a coarse reading but may get you in the ballpark.
    Note: In my experience the results you get from injectors can be difficult to draw definitive conclusions from - Depending upon whether you are in a developed pattern or not and how tight, the late time pressure can sometimes appear to simply asymptote to the injection pressures of surrounding injectors..... you may need to use a leap of faith and use mid-time slope to infer reservoir pressure..... It's certainly worth a look though, and as with most things while the absolute values may be suspect, by taking a number of these readings over time the trend is often more informative.
    Good luck
    Apr 2009
    south america
    Thanks buddy! but I had a little problem ... when I stopped the injection, the hydrostatic pressure was less than pressure of the sand, so there was a back flow. Know any case similar to what happened to me?
    Nov 2008
    Australia
    I'm not sure what to say here.... either I'm missing something fundamental, or you are ;-)
    Unless the injection well goes on vacuum straight away, you expect the well to have the potential to flow back initially.... the 'trick' is to close a valve on surface to prevent it flowing back, and to have a pressure gauge upstream of this valve to record the falloff.
  1. ESP and chemical injection??
    By hader in forum Oil And Gas Production
    Last Post: 09-06-2011, 02:15 PM
  2. CO2 Injection Well Design
    By ahme85 in forum Drilling And Workover
    Last Post: 08-22-2011, 09:27 AM
  3. water injection
    By pipeline in forum Pipeline And Fluid Flow
    Last Post: 11-26-2010, 02:48 AM
  4. Help with co2 injection!!!
    By gasengineer+ in forum Oil And Gas Production
    Last Post: 05-29-2010, 06:02 AM
  5. Gas Injection
    By rotanimod in forum Reservoir
    Last Post: 12-30-2008, 08:15 PM
