ELgharib - Interesting problem
Short answer unfortunately is no, I don'y have any material (or indeed experience) analyzing PBU tests in gas lift wells. I could well believe that you'd see two wellbore storage trends, masking your formation response quite badly. You may have to do something like running in a memory gauge hanging below a blanking plug to set in the x-nipple at the bottom of your tubing via slickline (hopefully below your last GL valve). Otherwise..... hmmm... you may be better off trying to model it with a RTA (rate transient analysis) package such as Fekete FAST RTA, which takes your flowing rates and estimates BHP's from fluid properties and lift curves to figure out formation parameters... at least then the wellbore storage should not be changing so radically.
Good luck
*Update: Have done some investigation, and the more appropriate tool apparently is FAST VirtuWell - you can get a demo download from [link Point to another website Only the registered members can access]
I have not used this software though.....
