Thread: which type of rubber expansion joint, sleeve type, has maximum working pressure?
    I am looking for a rubber (EPDM) sleeve type joint with single bellow, to connect two 4 inch ID pipe stubs using 1-2 hose clamps. Most i can now find on the internet is 6 BAR working pressure. Does anyone know a manufacturer or distributer who makes these type of joints for working pressures of 10 BAR (burst 30-40 BAR)??
    Have a google for FlexEJ but I beleive they are flanged units only. Using clamps for 10 Bar is not recommended and neither is it at 6 Bar for that matter.
    Thanks for the reply. Could you explain why this nis not recommended? When they are successfully tested on burst pressure it should be OK, or not?
    Fuller Valve is a place to ask for that joint. Contact person is Ian Watson.
    iwatson@fullervalve.com
    We can work with you to find a solution to your problem.
    Best Regards,
    TMN
  1. Wafer or lug type ?
    By ponnusj in forum Mechanical Engineering
    Last Post: 02-17-2014, 06:33 AM
  2. Expansion Joint
    By Debelme in forum Mechanical Engineering
    Last Post: 09-02-2013, 03:52 PM
  3. Valve type
    By Ahmed gamal in forum Mechanical Engineering
    Last Post: 07-25-2013, 01:04 PM
  4. Flow type
    By Syazwan Zubir in forum Pipeline And Fluid Flow
    Last Post: 07-11-2013, 02:59 PM
