Thread: Request Need Solution for the Case Presented
    Post Request Need Solution for the Case Presented
    Dear Members of ASPEN,HYSYS & CHEMCAD Community,
    I have joined the club very recently. I am working on a PFD which needs help from the experts in HYSYS. I am attaching :
    1. The input file(how do I upload in this forum??)
    2. The PFD showing various equipments
    3. The spread sheet showing the specs of different streams.(how do I upload in this forum??)
    The subject PFD is meant for ZERO FLARE and uses Howden single stage compressor with a compression ratio of 9.86. For the purposes of getting fairly a good discharge temperatures, I have construed the single staging as THREE STAGE which is depicted in PFD.
    As I am unable to solve the process, my humble request to the readers of the community to help me get a solution. The speard sheet gives the individual stream pressures and temperatures.
    Hope this material should be good enought to help you give me the solution.
    With regards and expecting a favourable responses,
    I remain,
    Yours friendly,
    Samrat
    Attached Files Attached Files
  3. Hi,
    Are you trying to size the screw compressor to achieve zero flaring?
    suresh
    Smile
    Quote Originally Posted by suresh72kumar View Post
    Hi,
    suresh
    Dear Suresh,
    I am not trying to size the compressor. The screw compressor size has been fixed. If you see my previous mail, what I am looking forward to is:
    1. How do I attach:
    a. The spreadsheet of the case study for your ready reference
    b. How do I attach the inputfile of Hysys to solve the PFD?
    Are you a chemical engineer? You might be familiar with the Hysys software. I am still in a learning stage being a mechanical engineer by profession.
    Please answer the above to enable me to present the case which I am not able to solve.
    In Hysys software, what is the function of:
    ..... ADJ icon and how this is a influincing the process stream?
    ..... RCY icon and how does this function and what is controlling parameter?
    Appreciate your response.
    samrat
    am981991@gmail.com
  1. Replies: 0
    Last Post: 02-24-2012, 07:40 AM
  2. [Request] Solution manual for "Design of Machinery" by Holowenko 1955
    By vlaxirious in forum Mechanical Engineering
    Last Post: 11-25-2011, 04:06 AM
  3. Replies: 0
    Last Post: 07-27-2010, 09:58 PM
  4. (Request) Tight gas / Stimulation case studies
    By reservoirengineer in forum Reservoir
    Last Post: 04-28-2009, 11:51 PM
