Thread: pipe welded
  1. Question pipe welded
    Hello
    I want to know if we have pipe welded ( not seamless) who can I calculate max temp. and max pressure that pipe can resistance with different fluid ?
    I know this formula from ASME B31.1, Para. 104.1.2 tm = P Do / (2 SE + 2y P) + C
    but it use for pipe welded or seamless and is there any different between welded & seamless pipe in ASME B31.1?
    Thank you
    Oct 2008
    The Netherlands
    Blog Entries
    14
    Get your material specification , for instance ASTM 333 gr. 6 seamless or whatever material you have whicj h is not seamless , but whicg is allowed by the Code
    If you work with B31.1 or B31.3 , based on your material find out the appendix at the end of the standard which gives you the value of=
    E = Joint efficiency , This E has a maximum value of = 1 ,
    The paragraph of the code defining the required minimum wall thickness will tell you where to look exactly.
    Introduce his value E in your formula ....
    Note that your allowable stress will decrease when the temperearuture gets hotter , say from 200 celsius,
    Now we have talked about a STRAIGHT pipe
    And so far you have the minimum required wall thickness for a straight pipe ONLY
    but the maximum allowable pressure might depend on any other possible fitting in your entire piping system, this can be a tee or a flange,
    the reason is that for relatively hight pressures the required thickness for a tee, a reinforced tee , or an elbow must be thicker that the matching pipe
    Check also and again the flange rating , because it might dictate the maximum allowable pressure
    If you do not understand the above 100 % , Please indicate the:
    Material
    The Code
    The design pressure
    the Maximum design TEMPERATURE
    the MINIMUM design temperature
    The corrosion allowance
    And if you yave flanges , tees,
    Take care
    See the following Thread of CR4 Forum:
    [link Point to another website Only the registered members can access] [IMG]http://img340.images****.us/i/80676579.jpg/[/IMG]
  6. Hello
    If material : A 106 Gr. B and medium is water and max. pressure is 10 bar
    At first I must refer to ASTM A 106 and see this code allowed to use welded pipe at certain pressure or no
    Is it correct ?
  1. Astm a312 smls and welded austinetic stainless steel pipe
    By piperbillym in forum Engineering Spreadsheets & Presentations
    Last Post: 07-16-2013, 05:54 PM
  2. Article: pipe welded
    By FATHI in forum Home Articles
    Last Post: 06-30-2010, 09:49 PM
  3. Spiral welded pipe or longitudinal?
    By pipeline in forum Pipeline And Fluid Flow
    Last Post: 06-23-2010, 03:30 PM
  4. question of pipe welded
    By javad64 in forum Pipeline And Fluid Flow
    Last Post: 05-07-2010, 10:06 AM
  5. pipe welded
    Last Post: 03-11-2010, 10:01 PM
