Results 1 to 1 of 1
Thread: Acoustical wall setup
  1. Acoustical wall setup
    hi, friends, here is my case: I am working on setting up an acoustical wall to separate the HPU room and the access way so that the noise in the access way could meet the NORSOK S-002 standard. However, there are a lot of pipes and cables in this room exactly blocking the setting up of an acoustical wall. Have anyone encountered the same situation? Do you guys have some suggestions or solutions? By the way, can anyone provide ISO15667:2000 Acoustics -- Guidelines for noise control by enclosures and cabins? thanks very much.
  1. plantwave setup
    By MEHUL in forum Pipeline And Fluid Flow
    Last Post: 05-08-2019, 09:59 AM
  2. Replies: 0
    Last Post: 09-16-2010, 09:16 PM
  3. Design of Water wall (Membrane wall) in waste heat boiler
    By srvinay2010 in forum Mechanical Engineering
    Last Post: 09-16-2010, 07:55 PM
