Results 1 to 5 of 5
Thread: Design of Low preesure Tanks as per ASME SEC.VIII
    Dear sir,
    Hay?? Can we design a low pressure tanks in ASME SEC.VIII , For Example in my case the Design Conditions are as given below
    Design pressure = 5 Psig
    Design Temperature = 60 C
    Design Code = ASME SEC.VIII
    Please help me in this regard.
    Deep
    Use API 620, ASME does not cover it. ASME VIII.Div 1 is applicale foe 15 psi and above.
  5. Quote Originally Posted by deep79pk View Post
    Dear sir,
    Deep
    If the design Code (ASME) has been specified by your client or user and if it is acceptable to the regulating bodies in your state/country, you can use ASME as the design code.
    Although the pressure of the above tank is below the ASME VIII Div.1 limits, you are still allowed to design the tank as per rules and requirements of the Code and even you can stamp the tank (U Stamp) if you want to. All you need to design is to follow all rules of the ASME code. Take the design pressure equal to 5Psig in the Code formula and that's it!
    However, be cautious about the minimum thicknesses and selected thicknesses. The ASME Code only gives you the minimum thicknesses required under pressure at the design temprature. But you might need to use much larger thicknesses due to handling and construction issues.
    API Committee allow it in Interpretation
  7. if the pressure is lower than atmospheric pressure then the design should be carried out for external pressure ( use code: ug 29)
  1. ASME VIII design strength
    By jmcgrath in forum Mechanical Engineering
    Last Post: 05-28-2018, 07:21 AM
  2. ASME BPV section viii div.1 design basic
    By sathish_iyengar in forum Mechanical Engineering
    Last Post: 05-07-2014, 04:26 PM
  3. ASME Sec VIII Div. 2 Design Calculation for preesure vessel.
    By trivedikr in forum Mechanical Engineering
    Last Post: 06-03-2013, 09:24 AM
  4. Expansion bellows design as per ASME Sec VIII Div 1 App-26
    By aspa in forum Mechanical Engineering
    Last Post: 01-18-2011, 09:38 PM
  5. ASME Sec VIII DIV2 Design By Analysis
    By Vesselman in forum Mechanical Engineering
    Last Post: 07-07-2009, 12:33 AM
